Onei 26av400
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    #81
    Re: Onei 26av400
    14 reads 304,16 reads 272 but when testing 16 the flashing stopped ?
      Re: Onei 26av400
      304V????? Are you sure?
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        #83
        Re: Onei 26av400
        3.04
          Re: Onei 26av400
          Better.
          When testing 16, LED on or LED off?
          • LEEDASH
            • Dec 2012
            • 481
            • Bedfordshire
            #85
            Re: Onei 26av400
            before i tested 16 it was flashing,placed on the meter and it stopped flashing,was just still blue.
              Re: Onei 26av400
              What did you measure when it did this? Perhaps re-touch soldering on pin 16.
              • LEEDASH
                • Dec 2012
                • 481
                • Bedfordshire
                #87
                Re: Onei 26av400
                that what i was thinking il try it
                • LEEDASH
                  • Dec 2012
                  • 481
                  • Bedfordshire
                  #88
                  Re: Onei 26av400
                  no change
                    Re: Onei 26av400
                    What do you measure now?
                    • LEEDASH
                      • Dec 2012
                      • 481
                      • Bedfordshire
                      #90
                      Re: Onei 26av400
                      roughly same as before,think im loosing the battle on this one
                        Re: Onei 26av400
                        It's important to state the voltage you are getting, rather than "roughly the same", as I have no idea what your definition of "roughly" is.
                        With a friend, I'm possibly working on a few Vestels over the weekend. One may be based on 17PW26, hopefully I will be able to help.
                        • LEEDASH
                          • Dec 2012
                          • 481
                          • Bedfordshire
                          #92
                          Re: Onei 26av400
                          that would be good
                            Re: Onei 26av400
                            Can't guarantee it, though. Last had an Alba a few months ago and that had a bad cap on 24V line.
                            • LEEDASH
                              • Dec 2012
                              • 481
                              • Bedfordshire
                              #94
                              Re: Onei 26av400
                              any more news on the vestel you were going to check out.
                                Re: Onei 26av400
                                Coming to me tomorrow and it may be a 37" 17PW20 type job with 2 secs to black so I may not be much help.
                                • ezenia
                                  Alba CBB16 replacement switches
                                  by ezenia
                                  I've been given an Alba CBB16 radio to look at. The issue was no sound from either speakers when switching to the radio. They'd just be some buzzing/static. I did some troubleshooting and found that if I mess with the switch in certain ways, the sound cuts in and out on the right channel speaker. It'll go from quiet with some static/buzzing to really loud and clear depending on how the switch is moved. This told me that the radio at least has an issue with this switch.
                                  The switch appears to be broken on the inside causing a poor connection. I tried cleaning it...
                                  07-29-2024, 07:05 PM
                                • adamski1952
                                  alba 10 tablet sdcard issue.
                                  by adamski1952
                                  Hi all.
                                  Im trying to access the sd card in my ALBA 10tablet directly from my pc, but when I connect using using usb its only showing the internal storage.
                                  I have a samsung tablet and it shows both internal and external storage when connected but no dice with the Alba.Is there some setting i'm overlooking.?
                                  My grandson has an amazon tablet and again the sdcard is not there when plugged in to pc.
                                  Thanks for any help.
                                  08-18-2022, 12:08 PM
                                • macsoftware
                                  I need help a bout surface book bios me region
                                  by macsoftware
                                  hallo friends my surface book touch screen won't working after me region clean , idon t have the original dump the chip winbond is damaged plz help me
                                  05-09-2021, 09:33 AM
                                • jimbofz
                                  horizontal "smear" panel fault?vestel alba lcd 40781f
                                  by jimbofz
                                  Hi this early vestel with inverter and ccfl backlight came in with no backlight and it was the usual suspects on the inverter board ,4 fets ao4616 ,i ordered a kit and repaired inverter .
                                  i now have this smear approx 8 inch from bottom on left hand side
                                  its about half inch wide it stops approx 3/4 across .it doesnt change with pic content
                                  i have examined panel closely for any damage ,
                                  none of the tabs are running hot .
                                  would value your opinions if it is the panel.
                                  ive had many plasma and lcd tvs with horizontal lines,
                                  but they usually go right...
                                  03-31-2021, 09:55 AM
                                • Blue132Red
                                  Alba LCD32947HD TV having strange picture problems
                                  by Blue132Red
                                  Duplicate thread created by accident
                                  05-25-2020, 02:53 PM
