Onei 26av400
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Re: Onei 26av400
    Yes the one in between 2m and 200
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Re: Onei 26av400
      Ok here is some of me readings
      on Q827k 1+2 1573,2+3 312,1+3/3+1 no reading,2+3 313,3+2 1570
      D893-no reading
      Q828 1+2 992,2+1 300,1+3 3+1 no reading,2+3 300,3+2 900
        Re: Onei 26av400
        Those devices appear OK. Any other devices marked "Dxxx"?
        • LEEDASH
          • Dec 2012
          • 481
          • Bedfordshire
          Re: Onei 26av400
          d884 d884 reading 524
          • LEEDASH
            • Dec 2012
            • 481
            • Bedfordshire
            Re: Onei 26av400
            sorry and d883
            • LEEDASH
              • Dec 2012
              • 481
              • Bedfordshire
              #26
              Re: Onei 26av400
              D893 no reading does this affect anything ?
                Re: Onei 26av400
                Where abouts is it on the PSU.
                • LEEDASH
                  • Dec 2012
                  • 481
                  • Bedfordshire
                  #28
                  Re: Onei 26av400
                  It was one you pointed out on the picture,not one of the 3 pronged ones
                    Re: Onei 26av400
                    May be bad pull one lead out of circuit and re-test.
                    • LEEDASH
                      • Dec 2012
                      • 481
                      • Bedfordshire
                      #30
                      Re: Onei 26av400
                      was the other two reading ok @ (524) the d883 and 884
                        Re: Onei 26av400
                        OK as long as no readng other way.
                        • LEEDASH
                          • Dec 2012
                          • 481
                          • Bedfordshire
                          #32
                          Re: Onei 26av400
                          thanks i will check the other one,if not is there any plan B.
                          • LEEDASH
                            • Dec 2012
                            • 481
                            • Bedfordshire
                            #33
                            Re: Onei 26av400
                            also tom is the a readings chart for this vestel board ?
                              Re: Onei 26av400
                              Not that I'm aware of..
                              • LEEDASH
                                • Dec 2012
                                • 481
                                • Bedfordshire
                                #35
                                Re: Onei 26av400
                                ok i will recheck the diode,is there anything else to check whlst im at this.
                                  Re: Onei 26av400
                                  If diodes are OK, we need to test some other things on PSU, like power supply outputs.
                                  • LEEDASH
                                    • Dec 2012
                                    • 481
                                    • Bedfordshire
                                    #37
                                    Re: Onei 26av400
                                    ok first things first i will check this one.
                                    • LEEDASH
                                      • Dec 2012
                                      • 481
                                      • Bedfordshire
                                      #38
                                      Re: Onei 26av400
                                      Check the diode again like you said pull one side out,no reading on this
                                        Re: Onei 26av400
                                        Can you get a picture of device if possible?
                                        Also what number e.g. D888.
                                        • LEEDASH
                                          • Dec 2012
                                          • 481
                                          • Bedfordshire
                                          #40
                                          Re: Onei 26av400
                                          d893
                                          • ezenia
                                            Alba CBB16 replacement switches
                                            by ezenia
                                            I've been given an Alba CBB16 radio to look at. The issue was no sound from either speakers when switching to the radio. They'd just be some buzzing/static. I did some troubleshooting and found that if I mess with the switch in certain ways, the sound cuts in and out on the right channel speaker. It'll go from quiet with some static/buzzing to really loud and clear depending on how the switch is moved. This told me that the radio at least has an issue with this switch.
                                            The switch appears to be broken on the inside causing a poor connection. I tried cleaning it...
                                            07-29-2024, 07:05 PM
                                          • adamski1952
                                            alba 10 tablet sdcard issue.
                                            by adamski1952
                                            Hi all.
                                            Im trying to access the sd card in my ALBA 10tablet directly from my pc, but when I connect using using usb its only showing the internal storage.
                                            I have a samsung tablet and it shows both internal and external storage when connected but no dice with the Alba.Is there some setting i'm overlooking.?
                                            My grandson has an amazon tablet and again the sdcard is not there when plugged in to pc.
                                            Thanks for any help.
                                            08-18-2022, 12:08 PM
                                          • macsoftware
                                            I need help a bout surface book bios me region
                                            by macsoftware
                                            hallo friends my surface book touch screen won't working after me region clean , idon t have the original dump the chip winbond is damaged plz help me
                                            05-09-2021, 09:33 AM
                                          • jimbofz
                                            horizontal "smear" panel fault?vestel alba lcd 40781f
                                            by jimbofz
                                            Hi this early vestel with inverter and ccfl backlight came in with no backlight and it was the usual suspects on the inverter board ,4 fets ao4616 ,i ordered a kit and repaired inverter .
                                            i now have this smear approx 8 inch from bottom on left hand side
                                            its about half inch wide it stops approx 3/4 across .it doesnt change with pic content
                                            i have examined panel closely for any damage ,
                                            none of the tabs are running hot .
                                            would value your opinions if it is the panel.
                                            ive had many plasma and lcd tvs with horizontal lines,
                                            but they usually go right...
                                            03-31-2021, 09:55 AM
                                          • Blue132Red
                                            Alba LCD32947HD TV having strange picture problems
                                            by Blue132Red
                                            Duplicate thread created by accident
                                            05-25-2020, 02:53 PM
