Need firmware for Magnavox 50" Plasma
  • jenslost
    • Feb 2013
    • usa
    This is a bit of a rant as well as a plea for help. I just bought a used Magnavox 50" plasma model #50MF231D/37 with an intermittent problem of sound and picture going off. The TV is about 5 or 6 years old, and the previous owners apparently never did the update. I have learned by the grace of google that the firmware update has resolved all these problems. I found the link to the instructions of the update:
    http://www.m4c.magnavox.com/cgi-bin/...5871&faqview=1
    I can not find the download for the update itself. I have contacted Magnavox who tells me to contact Philips who then refers me to Funai. No one can help. I am hoping that someone has saved this file, or at least has a good link to it. Thank you for your time.
    Re: Need firmware for Magnavox 50" Plasma
    What is the chassis code for your TV (it will either be in a box on the model sticker marked "S" or have "chassis" next to it.)
    • jenslost
      • Feb 2013
      • usa
      Chassis EP1.1U AA
      ....and i just got off the phone yet again with Magnavox and they informed me that my TV is a Philips Magnavox product, they have a website with no email and a phone that says they do not have any live support......nice.
        It might not be necessary to fix the firmware.
        Presumably these TVs were sold as working & after some time they stopped working properly? Due to some internal software problem? I have had this happen before. Whilst it doesn't fix the underlying cause, it usually gives the TV a few years extra before it goes wrong again... (and that can be fixed by resetting once more.)
        So, I usually try a service reset.
        Here is the service manual for your set:
        http://www.tgohome.com/ServiceManual...&Search=Submit
        To access service menu:
        Use the standard RC-transmitter and key in the code
        “062596”, directly followed by the “MENU” button.
        Note: It is possible that, together with the SDM, the main
        menu will appear. To switch it "off", push the “MENU”
        button again.
        • TheUser
          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
          by TheUser
          Hello to everyone ,
          This is my first post here, and i would like to share with you a small story in case you can help me.
          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
          02-10-2024, 02:07 PM
        • rumpumpel1
          ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
          by rumpumpel1
          Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
          10-24-2024, 08:59 AM
        • dkneyle
          Sony KDL-46HX850 Can't upgrade/update firmware
          by dkneyle
          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
          09-25-2024, 10:44 PM
        • pp74
          Marantz NR1508 USB firmware update image
          by pp74
          Does anyone happen to have the latest firmware for the NR1508? Marantz took their update server down and customer support refuses to provide the image to flash over USB.
          Regards
          05-10-2025, 11:55 PM
        • Faluky
          firmware for Marantz SR5008 stuck in update loop
          by Faluky
          After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
          Best regards.
          Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
          01-17-2023, 04:33 AM
