Samsung LE27T51B inverter problem
  • PowerAmpFreak
    • 982
    • Sweden
    Hello!
    Samsung LE27T51B, the inverter tries to start, a short noise sound is heard, but no backlight comes on. Please see attached picture.
    Is there any usual failures on those? Bad transformers?
    There are a bunch of SMD fuses, they're OK.
    The inverter does recieve +24V and ON-signal.
    Could anyone tell the resistance readings on the transformers.
    The transformers have marking "4006A533 008"
    Thanks in advance!
    Re: Samsung LE27T51B inverter problem
    Testing across the bulb connectors directly can sometimes work.
    • PowerAmpFreak
      • 982
      • Sweden
      I get different readings across the bulb connections.
      1. 12k
      2. 1k8
      3. 21k (?)
      4. 1k8
      5. open circuit (?)
      6. 1k8
      7. 12k
      Obviously there are two strange readings. So perhaps those two transformers are bad.
      Will it be worth a try to change transformers or better find a new board?
        Pin diagram, incl primary/secondary windings.
        http://www.lcdparts.net/TransformerD...ProductID=2740
        • PowerAmpFreak
          • 982
          • Sweden
          Great! Thanks tom!
            Does it have one of these black fuse (F5)?
            • PowerAmpFreak
              • 982
              • Sweden
              No, it appears to have only white SMD fuses. But they're all OK.
              • PowerAmpFreak
                • 982
                • Sweden
                Today measured the winding resistances of all the 7 inverter transformers.
                One of the them has one winding open circuit.
                Is it normal that one failed transformer will shut down the entire inverter?
                I assume all transformers with its associated drive electronics has fault detection and will disable all inverter action, correct?
                This boils down to the decision of either replace the faulty transformer or replace the entire board.
                But I think I'll go for the transformer change.
                  Yes, one transformer failed will shut down the inverter. The fault detection works on any bulb open, or any over-currrent of the bulbs.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    I repaired a TV with the same bad 4006A transformer. I bought mine from
                    http://www.ebay.com/itm/150706796810
                    $5.50 + free shipping.
                    --- begin sig file ---
                    --- end sig file ---
                      They look like typical DARFON transformers. Glad you found the cause of the problem.
                      • PowerAmpFreak
                        • 982
                        • Sweden
                        Great guys, I'll go for the transformer change. Thanks!
                        • eklunge
                          • Feb 2012
                          • 5
                          • hong kong
                          Usually if I found there is " two second to black screeb". I will displace the inverter board directly. Please let me know your outcome when you have replace the transformer.
                          It seems it should more cheaper to replace the broken than the entire inverter board.
                          • PowerAmpFreak
                            • 982
                            • Sweden
                            Yes, I will replace the transformer in a few days and gladly tell the outcome!
                            • PowerAmpFreak
                              • 982
                              • Sweden
                              One inverter transformer replaced and set is back to operation!
                                Nice one.
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  Wow, you got an inverter transformer from China in less than 5 days?
                                  • eklunge
                                    • Feb 2012
                                    • 5
                                    • hong kong
                                    Good job. Can you tell me where to buy the inverter yransformer. Thanks
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Seriously?
                                      Did you read Post #10???
                                      • PowerAmpFreak
                                        • 982
                                        • Sweden
                                        Not from China, but from a local component supplier!
                                          09-07-2024, 05:50 AM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • alro7779
                                          Samsung UN55MU6103F video problem; has colored stripes on the display
                                          by alro7779
                                          Hello, everyone!
                                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                          09-27-2025, 11:29 PM
                                          09-06-2024, 11:40 PM
