jvc LT-37X688 rolling shadows
  • nomoresonys
    • 12312
    • U.S.
    have large rolling very dark shadow on the left side now, sometimes it rolls from center to the left, sometimes the left about 1/3 of the screen freezes and the rest keeps going normal, after a while it goes away and works fine, but it can come back any time, sometimes the edge of the shadow will be red but usually its just dark, thanks for looking.
  • nomoresonys
    • 12312
    • U.S.
    Re: jvc LT-37X688 rolling shadows
    after warm up tapping the top usually clears up the shadow, but before its warmed up tapping does nothing, pretty odd.
    • nomoresonys
      • 12312
      • U.S.
      fixed it, you can close this thread now mod, thanks.
      • truep
        • Aug 2010
        • 373
        What was the fix?
        • karatzdi
          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
          by karatzdi
          I know some might say... just buy another one. Sell it as parts..!
          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
          Spent some time downloading the Service...
          06-11-2024, 08:38 AM
        • CoinCoin88
          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
          by CoinCoin88
          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
          09-15-2025, 03:36 AM
        • Pinky Deepak
          Vizio M60-C3 Left Edge problem
          by Pinky Deepak
          I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
          Here's a video of both the issues: https://youtu.be/hMqc760nB3o
          09-27-2024, 05:11 PM
        • armoured_smiler
          Panasonic Tx-40cx400b top left half screen not displaying correct
          by armoured_smiler
          Trying to work out if this is TFT problem or TCon issue.
          The TV powers up but the top half of the screen, from the right it is OK, but as you look across to the left halfway across it starts get duller and duller until it is very dark on the lefthand side, currently I trying to clean the remote as it seems to have something film wise on the pads stopping it from registering buttons pressed.
          Also when changing the screen size of Windows PC display to say to a smaller pixel sizewindow, the original window displayin the top left stays/takes a few seconds to disappear?...
          04-08-2024, 03:40 PM
        • Sik_6ty_Sixx
          HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
          by Sik_6ty_Sixx
          So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
          02-18-2025, 05:06 AM
