Panasonic TH-58PX600U 10 blinks
  • wmsproul
    • 12
    • us
    Noob here. Some electronic experience. I am working with a TH-58PX600u 10 blinker - pre power button. None of the TP's on the PA board are shorted to ground. All fuses good on the P-board. Ran through the trouble shooting guide and it seems to be coming from a faulty P-Board, it has bulging 900uf 220v caps 2 of the 3. Removed them from he board and they all meter ~854uf. I am getting around 34vac from the top of all four 220uf 450v caps on the P-board. Found that by accident. I shouldn't be seeing voltage from the top of the caps right. Any ideas?
    Re: Panasonic TH-58PX600U 10 blinks
    Watch https://www.youtube.com/watch?v=LjpGKaBt8hg and follow all of his steps.
    You actually only need to replace the ceramic capacitor next to the IC.
    • wmsproul
      • 12
      • us
      Would these be the ones? I watched the video and it obviously isnt the same power supply as mine. But these are locateed in the same location to the IC. Also the ones i need are 1uf 50v aluminum caps, right?
        You can determine if those are the problem using freeze spray as he showed in the video, so I'd recommend you try that. I've got no experience with this chassis myself.
        • wmsproul
          • 12
          • us
          They are not the issue apparently. I used the spray to cool the ic's but still received the 3 clicks and 10 blinks. I also tested by freezing both at the sametime and all individually. Why would i be seeing vac from the top of the caps??
            Can I see an overall shot of your PSU?
            The top of the capacitor is sometimes connected to one terminal or is sometimes floating to an internal node.
            • wmsproul
              • 12
              • us
              Here it is..
                Bottom of the board, near the brown cap, across from the white-on-black DEC relay would be my guess.
                • wmsproul
                  • 12
                  • us
                  Ok i guess i am not clear on what im looking for in the pic. I took a closer one of the area you described. Are you seeing a component/connection that could be bad?
                    I am looking at that stand-up board which may be the cause of your 10 blink code. Try freeze-spraying it to see if it sorts out the problem.
                    • wmsproul
                      • 12
                      • us
                      Ugh. No go, even after removing the stabalizing silicone. I tried every board with an ic. Still three clicks, ten blinks.
                        OK, try with the A Board disconnected.
                        • wmsproul
                          • 12
                          • us
                          Removed PA connections from the P-Board, no change, 3 clicks 10 blinks.
                          Removed SC connections from the P-Board, no change, 3 clicks 10 blinks.
                          Removed SS connections from the P-Board, no reaction, no blinks or clicks.
                          Removed D connections from the P-Board, no reaction, no blinks or clicks.
                          Make sense?
                            Maybe this training manual will help.
                            http://tgohome.com/ServiceManuals/?d...&Search=Submit
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Two of those nichicon GN 220uF capacitors on the top left of the PSU, they are bulged. I think though that will be only one of the problems.
                              Muh-soggy-knee
                                Although they look bulged, that would be very rare on this chassis. It's very nice to the caps and they're pretty good caps too. 10 blinks is a PA board failure, not Vsus failure - that would be 4 blinks.
                                • wmsproul
                                  • 12
                                  • us
                                  Should i just replace the pa board?
                                    If you can get it cheap enough, otherwise, there is a schematic of it I think, so it can be diagnosed.
                                    • wmsproul
                                      • 12
                                      • us
                                      New PA board is on it's way.
                                      • wmsproul
                                        • 12
                                        • us
                                        Well replaced it with a new pa and nothing changed. Still not working. Could those caps be bad? Back to the drawing board, start trouble shooting from the beginning.
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Biruslapio
                                          Panasonic P58V11B 8 and 12 blinks error "fix"
                                          by Biruslapio
                                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                          04-13-2021, 07:13 AM
                                        • jm1234
                                          Panasonic plasma TX-P42ST50 - 6 blinks
                                          by jm1234
                                          anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                          It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                          I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                          I checked that board for any obvious faults...
                                          05-22-2024, 06:59 AM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • CrewmanRedShirt
                                          Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                          by CrewmanRedShirt
                                          Hello all,
                                          As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                          07-13-2024, 11:02 AM
