Panasonic TC-P50S2
  • bobbyd40
    • Dec 2012
    • 116
    • usa
    Panasonic TC-P50S2
    Blinking red light ,10 blinks.
    unplugged SS board still blinks 10 times
    replugged SS and unplugged SC 7 blinks
    SU and SD unplugged from Sc 10 blinks
    There is a white light bulb next to where power in goes to SC board ( circled in Pic 3) does this light light up with power on ?Because it does not light even briefly when power cord plugged in or power on button pushed.
  • bobbyd40
    • Dec 2012
    • 116
    • usa
    Re: Panasonic TC-P50S2
    Sorry fuses are all good none open> that bulb does show as open on DMM
      SC is failed, check resistance between Vsus and GND on SC.
      • bobbyd40
        • Dec 2012
        • 116
        • usa
        Hi Tom, Ok i checked it at the Vsus connector with it unplugged i checked pins at the board and got 00.3 on one leg and .481 on the other leg.
          So it looks shorted; check for shorted FETs on the board. Also try with buffers isolated.
          • bobbyd40
            • Dec 2012
            • 116
            • usa
            Ok will do and report back. thanks again
            • bobbyd40
              • Dec 2012
              • 116
              • usa
              there are 17 on the board i have tested them all once and getting very different readings on most all of them. Going to retest them all again,you mentioned to try with buffers isolated how do i do that?
              • bobbyd40
                • Dec 2012
                • 116
                • usa
                just unplug them from sc?
                  Yes, EVERYTHING unplugged from SC. They may screw in - this is power signal. Make sure that they are not touching the SC. You can leave them connected to the panel. I don't recommend removing them from the panel as it's a pain in the ass to reconnect them.
                  You should test from the middle pin (may be bent forwards) to each of the outer pins.
                  A zero or near zero (<100) reading on diode test indicates a suspect device.
                  • bobbyd40
                    • Dec 2012
                    • 116
                    • usa
                    ok may be in the morning to retest had enough of this one for tonight. will reply back to you any out of range thanks again.
                    • bobbyd40
                      • Dec 2012
                      • 116
                      • usa
                      Hi Tom ,Took the SC board right out for easy testing.Here are the readings i got.
                      1.316
                      .515
                      .962
                      .002
                      .002
                      .002
                      1.403
                      .334
                      1.124
                      .339
                      .339
                      .339
                      .339
                      .339
                      .002
                      .002
                      .002
                      .002
                      .002
                      .002
                      .002
                      .006
                      .002
                      .006
                      .007
                      .002
                      .007
                      .516
                      flashes 1.886 and then goes to OL
                      .602
                      .002
                      .005
                      .005
                      .012
                      .002
                      .012
                      .010
                      .002
                      .010
                      .002
                      .002
                      .002
                      .002
                      .002
                      .002
                      .385
                      1.358
                      .002
                      .002
                      .002
                      .002
                      Have posted a pic of underside of SC board with this.
                      • bobbyd40
                        • Dec 2012
                        • 116
                        • usa
                        here are pics of sc board top and bottom
                          You'll need to remove each of those devices reading near zero (002, 006 etc.) and test them out of circuit.
                          • bobbyd40
                            • Dec 2012
                            • 116
                            • usa
                            Ok will do. thanks
                            • bobbyd40
                              • Dec 2012
                              • 116
                              • usa
                              Hey Tom have not pulled them from board yet .Did some further testing from Panasonic trouble guide and seems to be problem with the A board.I removed it to look at it and found a funny looking transistor on it. I am posting pics of it can you tell me if its normal to have a gob of solder coming out of it on both sides from the what looks like vents?Thanks
                                That is an inductor, not a transistor. It looks normal to me.
                                • bobbyd40
                                  • Dec 2012
                                  • 116
                                  • usa
                                  OK thanks Still learning here and have learned a lot from this board and the great guys on it.
                                    Q9004 probably refers to a nearby device or is a mistake.
                                    • bobbyd40
                                      • Dec 2012
                                      • 116
                                      • usa
                                      Hi Tom i have a question on a zener diode.I checked them all on psu and one on psu at z206 in pic 3 in post one reads .707 one way and 1.647 the other wouldn't that 1.647 indicate a bad diode? all the others read .707 and OL the other.
                                      Thanks again
                                        If in circuit, pull it and re-test. If it reads the same it's bad.
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • Alicat
                                          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                          by Alicat
                                          Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                          Model number is TH-50PZ85U
                                          Power comes on and the red power light stays on solid.
                                          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                          I also hear a few clicks.
                                          I also think my parents said there was a thunderstorm and the TV failed after that.
                                          Section 6 in the service manual talks about power and no screen,...
                                          10-30-2024, 10:09 AM
                                        • Elecfronicsssss
                                          DA0NJJMBAG0 charging light blinks
                                          by Elecfronicsssss
                                          Laptop motherboard DA0NJJMBAG0
                                          PROBLEM-WHEN I PLUG THE CHARGER WITHOUT BATTERY THE CHARGING LIGHT BLINKS AND WHEN I PRESS POWER BUTTON THE CHARGING LIGHT STOPS BLINKING AND STAYS ON BUT THE POWER LIGHT DOESNT TURN ON AND LAPTOP ALSO DOESNT TURN ON NO FAN SPINS NO KEYBOARD LIGHT.
                                          CHECKED- ON S5 STATE TGE LAPTOP HAS 5V ON USB 3.3V BUT I DIDNT GET 1.8VOLTS ON BIOS PIN NO 8 WHILE PLUGGED IN AND EVEN ON S5 STATE.
                                          GUIDE ME WITH THE PROBLEM..
                                          SUMMARY-
                                          1.NO 1.8VOLTS ON BIOS PIN NO 8.
                                          2.S5 STATE ((PRESSING POWER BUTTON)))VOLTAGES ARE PRESENT...
                                          05-12-2025, 02:32 AM
                                        • mecha1166
                                          XR-77A80K Dead set, red light blinks 8 times. Cannot find error code list.
                                          by mecha1166
                                          I have a XR-77A80K here. When plug in & press power, white lindicator light flashes on & off. about 30 seconds later, indicator light flashes 8x red. Checked Sony, Power reset = unplug & plug in. Factory reset involves turning it on, then pressing remote buttons when a picture shows. Well, neither of these "resets" are for a dead set like this. Anyone know what 8 blinks indicates, from the schematic? Thanks!
                                          07-01-2024, 05:47 PM
                                        • kca
                                          Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                          by kca
                                          Hello all ~
                                          I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                          This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                          No picture. No sound.
                                          I tested all the voltages coming out of the power supply...
                                          10-12-2023, 05:23 PM
