IPOS-150 power supply could use help almost there i think
  • davewilson61
    • 110
    • usa
    This is from poloroid tv tda-03211c
    boy am i lost here... what i did, spent 3 hours reading every post about this IPOS 150 power supply can't get it going..I gotta be close
    1) power up tv ...red led not lit on ps board or front of tv..really dead
    2)press power on tv....still dead
    3)check ps volts on com3...see below
    4)check f1 and f2 =good
    5)re-solder all old conections and parts
    6)checked D10 and D2
    7)changed alll capasitors
    8)used 2 AA batteries in series to give STB 3V ...I read that someplace. dead..still
    9)bridge is good ot 5volts
    10)got 7 large transisters or voltage regulators...not sure how to test
    11)voltage across main cap is 167v with com3 un-plugged .....plugged in its 320v
    only thing the 2 large capasitors are 47uf 450v should be 10uf 450v...someone changed them...would that matter? part of the backlight stage?
    STB =0
    5VSB =5V
    5V =0
    20V =0
    do have 5Volts dc... somethings alive...
    got some pics of the board
    I hate to buy a board...thats cheating and no fun
    Thanks for any help david
  • gilly1984
    • 751
    Re: IPOS-150 power supply could use help almost there i think
    No longer relevant.
    Do NOT touch heatsinks when testing for voltages as they may be LIVE!
    • davewilson61
      • 110
      • usa
      sorry missed the "0"...long day
      • gilly1984
        • 751
        Ah its 10uf 450v. Not sure if it would matter, someone will let you know soon pal.
        • gilly1984
          • 751
          Also, that main filter cap on mine was 450v, unless thats because I am in the UK.
          • davewilson61
            • 110
            • usa
            thanks
            • gilly1984
              • 751
              Have you tried the sometimes overlooked simple things?
              Power switch working?
              Tried with remote?
              Sorry I am not much help, Big boys will be here soon
              • davewilson61
                • 110
                • usa
                voltage across main cap is 167v without com3 un-plugged .....plugged in its 320v
                • davewilson61
                  • 110
                  • usa
                  guess what...its up...small white connector to power switch was unpluged...couldnt see it ......thanks gilly1984...it was over looked....simply things...cost 3 days of brain pain....but still would think the red led would light on the ps board...guess not or its out
                  thanks again
                  • gilly1984
                    • 751
                    The led on the psu is for fault codes. If there are no faults it will not come on.
                    • davewilson61
                      • 110
                      • usa
                      beer and pizza for you.....lol...and i dont have to stay up till 3am trying to fix this anymore
                      • gilly1984
                        • 751
                        Get on CL and join us some more
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
                          by sam_sam_sam
                          07-01-2024, 06:34 AM
                        • JimBanville
                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                          by JimBanville
                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                          09-13-2023, 07:21 AM
                        • Andreas_de
                          Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                          by Andreas_de
                          Hello!
                          i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                          Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                          Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                          04-12-2025, 10:38 AM
