Samsung le32r81bm/xtl
  • karkera
    • Jan 2012
    • 5
    • INDIA
    Have a TV SAMSUNG LE32R81BM/XTL, the problem is that the set enters in Standby mode, without any response to Remote or physical touch of the switch. Have checked the SMPS Board with another working LE32R81BM, it works fine, the problem is with the main Board BM41-00839B (2007.02.21), the A5V is available, A3.3V is also available, the oscillations at SUB MICOM IC is also OK, now the power ON/OFF signal to the SMPS is not obtainable, have checked the operation of KEY INPUT 1 and KEYINPUT 2, through the scope, using the remote control at the SUBMICOM input, it is fine, still cant figure out the problems... the board schematic says that 13VDC should be available from the SMPS Board, but I cant understand how this would be possible since the SMPS should start from the signal SW_PWR coming out from the SUBMICON...
    Can someone who has worked on it or encountered such standby problem help me out...would be glad... as I may have missed some thing...
    Many thanks in advance,
    karkera
    Re: Samsung le32r81bm/xtl
    It is possible for the touch switches on these models (I think it uses touch panel, not real buttons) to fail, causing erroneous key presses. Have you tried to start it with the touch panel removed?
    • karkera
      • Jan 2012
      • 5
      • INDIA
      I had checked with the entire LCD unit including frame by interchanging them on a working set, so I think that's ruled out and confirms the problem with the main board....any other infor / fault /guide???
      Best Regards
      karkera
        I'm talking about the board which holds the controls for the buttons on the side of the unit, power on/off, standby, etc. Or is this model using a single power on button and side controls as well?
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • ohren
          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
          by ohren
          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
          The models launched in 2018 and 2019 respectively....
          09-08-2023, 05:24 PM
        • C152Heavy
          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
          by C152Heavy
          Summary for TL-DR readers:
          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
          • Have obtained Samsung schematic & service documents - Can upload if helpful.
          • Have read ALL applicable threads
          • C1818 and CP820 replaced as low hanging fruit
          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
          09-07-2024, 05:50 AM
