magnavox 37mf321d no remote
  • jschettler
    • Dec 2012
    • 8
    hope someone can help
    i repaired my power supply bad caps i also had a bad scaler (main) board
    i replaced the main board now the tv works fine except i have no remote control
    i tried 3 different universal remotes thinking the code might be different
    how can i test to see if its the ir board or main board? it must have been hit by a surge to damage both boards thanks jack
    Re: magnavox 37mf321d no remote
    You can use a digital camera to see if the remote control is sending out the right pulses. IR light is visible on most digital cameras.
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • cheeky2
      by cheeky2
      05-25-2024, 03:27 AM
