Intermittent fault with Phillips FlatTV - bad inverter?
  • Katch
    • 7
    Just thought I'd ask a second opinion before getting a spare inverter for my TV.
    TV is a model 26pfl5522d - when turning on it flickers in large horizontal bands. You can see the picture but it looks like the contrast is low and the brightness high - blacks appear washed out (although over all brightness output is lower than when the fault stops)
    After a few minutes the screen pops back to normal - sometimes taking up to 10 or 15 minutes. Once this has happened the fault does not reappear until the TV has been left turned off for some time. Occasionally the fault does not occur at all.
    I can shoot a video and post on youtube if need be - my gut instinct is the inverter board.
    Re: Intermittent fault with Phillips FlatTV - bad inverter?
    I've seen this before with the bigger brother to this, the 37PFL7662. It's a failing LCD panel, it's often easy to fix though.
    https://www.youtube.com/watch?v=purk_SyiT44
    It is not an inverter fault as far as I am aware.
    • Techstar
      Tv Restoration
      • Dec 2012
      • 122
      • United Kingdom.
      That would be a good start to post a video. The t -con boards on this tv fail
      often so does the tab bonding, if it was me and i suspected a faulty inverter i would check the inverter board with my magnifier lamp for anything obvious before ordering replacement parts. Have you done a visual inspection of the suspected inverter board yet ? Checked and cleaned connectors ? .
      • Katch
        • 7
        Hmmm the fault in that video is not like the one I am experiencing.
        The fault with this set occurs across the entire panel - if you feed the panel a fullscreen black (by using hdmi off a laptop etc) you will see an over all washed out black and thin horizontal banding.
        As the screen warms up it seems to flicker in 3 distinct horizontal bands (roughly thirds) - the flickering is that third popping to normal for a second before going back to washed out. Then all of a sudden the whole panel pops to normal.
        EDIT - I haven't had a chance to get a look under the hood yet.
          Yes, it may not be the same fault, but the root cause is the same. It is the tab bonds on the LCD panel.
          I've seen exactly what you are talking about. It's not too difficult to fix on a 26".
          Here is my telly after making a repair to the inverter (it has same fault, shorter time though): https://www.youtube.com/watch?v=HIAYwDKwT0Y
          • Katch
            • 7
            Hmmm it could be - unfortunately mine is on and warm so it won't show the fault again till I leave it off for a while.
            I'll take a video next time and check the tab bonds if I get a chance tomorrow.
            • Katch
              • 7
              Here's an update then. Not had a chance to open the set up yet but here is a good video of my problem.
              http://youtu.be/J6SXjfrx6_U
                It looks a little like the beginnings of my problem as shown in the video.
                However there's the chance too that it's the LVDS connector.
                • Katch
                  • 7
                  so i'm opening her up now - lets see...
                  • Katch
                    • 7
                    hmmmm ok - so here's what I did,
                    opened it up and put rubber shims on top of the 6 tab bonds on the top and the 3 down the left hand side.
                    Turning on - the flicker has gone.... but so has the picture. Sound works as expected...
                      You have to be very careful when working on the panel as it is easily possible to chip it or damage some of the flex ribbons. Double check your work. I chipped the edge off a 40" Sony while doing this and was greeted with some slowly fading lines, no picture remained.
                      • Katch
                        • 7
                        have removed my shims - picture is back and not flickering.... lets see if the issue returns in a day or 2.
                        Only thing I can think of that caused the picture to disappear is that my shims were pushing too much... not sure. Lets see.
                          You just want to apply enough pressure to get the picture back but not any more.
                          • djdanielb
                            • Italy
                            Hi people I'm Daniele.
                            Nice to mmet you !
                            I've the Philips 3PFL7662 with the famous problem showed in the post before.
                            I've just change AS15-F on T-con board
                            but no solution
                            Same problem...
                            Any idea ??
                            Many thanks
                            Daniele
                              Should I take this undertaking “ Fault & Not Work 8000W LF Split Phase Pure Sine Wave Power Inverter DC24V/AC110V”
                              Is it worth the time to investigate what is wrong with this inverter according to the seller they offer repair parts I asked them what parts do they offer as repair parts cost $159.00 free shipping...
                              06-12-2025, 06:46 AM
                            • jimbofz
                              lg 32LC46 backlight inverter board fault
                              by jimbofz
                              Hi this oldie had no backlight .after replacing caps on 24v rail ,
                              still no b/l this uses inverter type:1315 B1-16A,
                              im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                              all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                              this allows protect to be temporary overridden.
                              b/l now comes on
                              but the left hand side of pic is gradually darker than the right side
                              i have the cct for the tv
                              but it does not have inverter cct.
                              i opened it up to inspect the ccfl tubes
                              and they dont have any...
                              12-19-2021, 06:58 AM
                            • x_orange90_x
                              Vizio E55-E1 bad backlights or bad inverter?
                              by x_orange90_x
                              I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                              I don't know how exactly to test the inverter itself. Is it...
                              01-29-2025, 09:24 PM
                            • Rictech
                              Panasonic SA-MAX770PU SMPSU board fault....
                              by Rictech
                              Hello everyone. 😀
                              As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                              Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                              Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                              This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                              There are no devices that have exploded or otherwise show signs...
                              08-26-2024, 01:05 AM
                            • protocold
                              MacBook Pro 15" 2010 820-2850 intermittent charging
                              by protocold
                              I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
                              I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
                              when it is not intermittent:
                              PPVBAT_G3H_CHGR_R is 12.07v
                              when it is intermittent:
                              When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
                              when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
                              data line on the battery...
                              07-25-2025, 08:18 PM
