Samsung PS50C6500 no video but sound
Re: Samsung PS50C6500 no video but sound
Yea I'm well impressed I managed to repair / upgrade it
So yea thank you so much, if it goes again which I suspect it will I'll know what to do and / or if needed I'll be back. You certainly know what your doing hope you have a good career when you graduate, take care!Comment
Another quick update: After using it again for over a day I can say that the picture quality is better; less noise by a lot (had loads of pixels bouncing around everywhere before, had to look carefully to see them though, but now no longer). Also the only downside so far seems to be a delay in channel audio, when changing channels it now takes 5 secs for the audio to kick in, minor con for such a big gain.
Edit: Nevermind, fixed the sound, went into the service menu and enabled some features, all good now.Comment
Bizarre necromancing there, FTP.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Noticed there were a number of refer links from this forum and thought I would check it out.
Thank you for your continued support.
Any feedback at all?Comment
Used you before. Appreciate your not insane pricing which has led to a purchase from myself previously, saved a Samsung LCD TV from the dump. When parts cost is more than about £40, I start considering stripping a TV for parts instead of repairing one.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
OK, get a piece of wire or a hard-disk drive jumper and place it across pins 3 and 4 here. The white numbers are adjacent to the pins.
Disconnect the brown cable between main board and control board. Leave everything else connected.
Power up the TV and see if you get test pattern(s) on the display.
please tom66 I have currently this problem my samsung ps50c6500 ...when put on , makes a welcoming sound after that nothing happens ,no picture no light on the screen. ...I have try to contact or write u but not allowed.
Any help will be appreciated.Comment
by gl4709I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
by Max514Hi all,
Ok so I have this beautiful un55h8000 samsung tv with sound but no video nor backlight. When turning the set on the red light blinks 5 times.
The screen shows no damage and backlight turns on when I disconnect the power supply from the main board. The tcon board only has 2 out of 3 leds on.
I came across this page and followed the different steps: https://techhometravel.com/samsung-u...ight-no-video/
- Unplugging the main board cable at the power supply >>> backlights came on.
- BLU_ON signal from the
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by alro7779Hello, everyone!
A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,... -
by soerenI am facing a strange issue, I don't have any sound over my internal MacBook speakers and also the video won't start. If I change to my head speaker or via HDMI (speaker on my external Display) the sound works over the head speaker or Display and also the video starts (ex. youtube).
All happened after the battery ran out of power overall several days when I was on vacation.
I tried to remove the battery and then reconnected the battery, and then the MacBook Pro 14 2021 won't accept any power from my power socket. Then I removed one speaker, connected again the battery... - Loading...
