toshiba 52RV535u help! pink band on screen
  • ealequi
    • Dec 2012
    • 212
    • usa
    I replaced the t-con board and the main board and it still doing the same. I dont know if maybe the screen is bad or it may be the inverter. Help please.
  • ealequi
    • Dec 2012
    • 212
    • usa
    Re: toshiba 52RV535u help! pink band on screen
      This is most likely the LCD panel at fault, it may or may not be repairable.
      The t-con and main cannot usually cause localised distortion.
      • ealequi
        • Dec 2012
        • 212
        • usa
        should i go into the panel conection and check or is a lost cost?
          For a 52" I think it's worth at least trying to fiddle with the tab bond.
          • ealequi
            • Dec 2012
            • 212
            • usa
            I going to try and i let you know the end result. Thanks.
            • jimjoe123
              LCD TV Green/Pink screen problem
              by jimjoe123
              I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
              Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
              Then each time...
              02-23-2020, 01:29 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
              09-06-2024, 05:27 AM
            • sigmeyer
              Toshiba 50UL4B63DG faulty screen?
              by sigmeyer
              I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
              08-30-2025, 08:13 AM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
