Samsung HP-S4253 Rapidly Flashing Screen
  • johnboy1313
    • Nov 2012
    • 1959
    Just picked up this Samsung plasma for next to nothing. At the time I went to check it out, it was doing this on the VGA input, but stopped when I changed to the AV input. I brought it home, connected my DVD player to it and watched a few movies with no issue whatsoever. This morning, I turned it on and the screen was flashing on every input. It flashes from super bright to normal about every half second at a steady rate. I haven't opened it up yet. I've got two other plasma sets on the bench right now. I'm just wondering where to start when I do get it opened up, probably later today.
    Here's a video
    http://s177.beta.photobucket.com/use...E3F3B.mp4.html
    Re: Samsung HP-S4253 Rapidly Flashing Screen
    When the plasma screen is going very white, it is arcing over internally and most pixels are being forced on (wall charge on each cell is sticking.)
    This means one of two things:
    - Vs which is normally 180~210V (typically 205V for a Samsung of this generation) is probably exceeding 220V, maybe 230V (possibly just a dirty/dodgy potentiometer); OR
    - Yrr/Yfr are set incorrectly (tieny just fixed a similar 50" with a similar problem, except his was arc-bright all the time.)
    Since it is regular I suspect a feedback problem with the PSU; it is not able to keep the Vs at the right voltage and the over-voltage or over-power protection (from the too-bright display) is kicking in.
    Avoid running it for too long as damage may be dealt to the Y-Main or X-Main. A dim screen may cause Vs to far exceed rated voltage and cause damage due to lack of functioning OPP at low brightnesses.
    • johnboy1313
      • Nov 2012
      • 1959
      How long is too long? I don't want to screw something up just probing for voltages.
        No more than 5 minutes at a time. I'm guessing here, as I wouldn't know for certain. Just don't try and leave it on for an hour and see if it will rectify itself...
        • johnboy1313
          • Nov 2012
          • 1959
          Ok, with y-sus, or whatever it's called on a Samsung, plugged in I get...
          Va = 57 - 65
          Vsc = -204 - -217
          Vs = 183 - 303
          Ve = 107 - 123
          Vset = 127 - 163
          With ysus unplugged, in the same order...
          67
          -191
          202
          113
          185-210
          The label shows these voltages, in the same order...
          65
          -185
          197
          110
          195
          Just guessing, but I would think my next step would be to disconnect the buffer from the ysus and test the voltages again with the ysus plugged in.
          • johnboy1313
            • Nov 2012
            • 1959
            Forgot to add. With zsus disconnected, in the same order as above...
            69
            -193
            208
            116
            193-215
              Vs 303V?! Holy *#@! The PSU and sustains are rated to 250V, by nature of the capacitors alone! The IGBTs and FETs are usually 250V, max!
              The panel should be arcing over internally by that point. That doesn't seem right?!
              Your PSU is completely unstable but for some reason works better under no load. Dried output caps or bad feedback could cause this issue.
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                As tom said, yeah, definitely a problem with the PSU! Wow! Sometimes this happens in computer PSUs and the mother board gets toasted
                Well, its time for the opening ceremony!
                Muh-soggy-knee
                • johnboy1313
                  • Nov 2012
                  • 1959
                  So, I'm thinking my cheap DMM may have got me here. I downloaded the service manual tonight and saw that there are specific test points for the voltages. With everything connected, from the test points I get...
                  Va = Steady 65V (Normal)
                  Vsc = Steady -197V (Low, I was able to adjust it up to -186V)
                  Vs = Steady 197V (Normal)
                  Ve = Steady 109V (Normal)
                  Vset = Fluctuating 123V - 168V (Low and all over the place, adjusting doesn't seem to help make any difference))
                  Even when testing from the harnesses, it does still fluctuate a little, but I still don't see 303V at Vs
                  Here's the manual if you wanna look at it.
                  In all of the probing, Vset seems to be my problem. What now?
                    Yes, Vset can definitely cause this issue.
                    The little sub-power supply board has a problem on it as that generates the Vset.
                    Some fluctuation in Vs is tolerable. One standard I saw said allow +/-1V from fully dark to fully bright. Vs is directly proportional to the picture brightness, and the complete discharge of the panel. Low Vs will cause underdiffusion (misfiring or dark stuck pixels.)
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      What do you suppose would cause the fluctuation in Vset? There's a 350V 47uf cap just off of the Vset leg of the sub-PSU. I swapped it out with one that I had in my parts box and still get the same fluctuation. These boards are very inexpensive. There's one on the auction site right now for 15 USD shipped. Right now, I think I may be money ahead to just buy this board and replace the whole thing. What do you think?
                        I would go for it. Someone else had the same problem with an unstable Vset. My guess would be some loss of regulation (feedback problem) or perhaps a bad start up capacitor causing controller instability.
                        Vset is used in the Yfr circuit to generate the positive ramp waveforms. A fault here could also cause the problem, perhaps due to excessive load. How stable is it with the Y-main disconnected?
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          ~185v-210v
                            OK, I would first inspect the board for cold joints, try adjusting the Vset potentiometer (a dodgy pot can cause this problem.) If those fail then consider a replacement of the board.
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              I tried adjusting the pot, it doesn't really seem do do anything when turned either direction. I went back and looked at the board for sale and it was on sale for $11.99 shipped. I went ahead and bought it. It should be here by Monday. I'll let you know how it goes.
                                I would probably not spend any more than 30 minutes having a look at repairing a fault on a board when I can get it for $12.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  Got the new board in the mail and installed. All voltages are steady. Picture doesn't flash anymore. I'm going to do the fine adjustments shown in the service manual and run it for a couple days. Thanks for the help.
                                    Glad to hear you fixed it. Plasma TVs really aren't that hard.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      I've fixed 2 of 3. I still don't understand what's going on with the third one. I plan on getting into it again tonight.
                                        Have you got a scope yet?
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                          by JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                          Please help. Thanks in advance!
                                          08-12-2025, 11:45 AM
                                        • Kiberge
                                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                                          by Kiberge
                                          HI guys!
                                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                          04-22-2024, 11:28 AM
