sanyo no back ligth
  • ealequi
    • Dec 2012
    • 212
    • usa
    sanyo no back ligth
    I have a sanyo dp42647 when i turn it on there is a black screen with sound. If i put a flashligth close to the screen i can see the video. Any idea?
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: sanyo no back ligth
    It's 100 times easier if you post close up clear pictures of all the boards and have a multimeter ready for troubleshooting
    • ealequi
      • Dec 2012
      • 212
      • usa
      I still learning how to use this forum. I has to learn how to load the pictures
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        When replying click Go Advanced, and attach the pictures using the Attachments button
        • ealequi
          • Dec 2012
          • 212
          • usa
          ok
          • ealequi
            • Dec 2012
            • 212
            • usa
            • ealequi
              • Dec 2012
              • 212
              • usa
              • ealequi
                • Dec 2012
                • 212
                • usa
                sorry. this is the main board, not the red one
                • MisterD
                  • Oct 2012
                  • 668
                  I suggest that you post the Model Number and also take some closeup pictures of the white connectors on the power supply board and be sure that the picture shows the markings on the circuit board at the connector that tells us which pin is which, usually the markings are Stby, PSON, BL_ON, 3.3V, 5V, 12V, 24V.
                  • jetadm123
                    • 2169
                    Also post a good focused photo of the bottom of your power board.
                    • ealequi
                      • Dec 2012
                      • 212
                      • usa
                      ok i will
                      • ealequi
                        • Dec 2012
                        • 212
                        • usa
                        Ok this are the new picture for the sanyo DP42647
                        • ealequi
                          • Dec 2012
                          • 212
                          • usa
                          • jetadm123
                            • 2169
                            Need a photo of the bottom of the power board.
                            • ealequi
                              • Dec 2012
                              • 212
                              • usa
                              • MisterD
                                • Oct 2012
                                • 668
                                Originally posted by ealequi
                                ok i will
                                Sorry, I didn't see the Model Number in Post#1 is sanyo dp48249, I looked at a backlight inverter board like yours at shopjimmy.com and I see that it has some fuses they appear to be white with gold ends, you should check continuity of these fuses to make sure they are not open.
                                • ealequi
                                  • Dec 2012
                                  • 212
                                  • usa
                                  ok i will do that now. thanks
                                  • ealequi
                                    • Dec 2012
                                    • 212
                                    • usa
                                    No. this has no inverter board. just the t-con board
                                    • MisterD
                                      • Oct 2012
                                      • 668
                                      with the tv powered on, check the voltage on the small white connector that has the 3 black and 1 white wire, it's near the edge of the power supply board, I see it is labeled BL_ON, hook a volt meter with the black probe to chassis ground and use the red probe at the connector making sure it touches the metal part where the wire goes in, set your meter to DC Volts, report the voltage reading back here.
                                      • MisterD
                                        • Oct 2012
                                        • 668
                                        Okay, maybe the inverter is included on the Power Supply board.
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 08:10 PM
