Akai 40lw7
  • unicor
    • Jul 2010
    • 7
    • INDIA
    Akai 40lw7
    The TV set is in standby. it does not switch ON.
    The main mother board is CULTRAVIEW CV028GH_MA_V3.
    The power supply is okay. 12V comes to the main board. 24V also comes if i force the power supply ON.
    The 5V are present on the main board.
    Pin 43 of microcontroller TP2808HQN becomes low when power On is pressed on front panel but Pin 44 does not go low to switch on the TV.
    Can the memory IC cause the problem.
    Any help.
    Thanks.
    Re: Akai 40lw7
    Can we see the pictures of the boards? We need to see the labels on the connectors, since you do have 12v and the 24v, which means the main board is sending the PS_ON signal to turn on the power supply OK, next signal we need to find on the connector on the power supply board or on the inverter board is the BL_ON SIGNAL which will turn on the backlights.
    Please use 'GO ADVANVED' to upload the pictures.
    OK, you indicated that you have to force on the power supply, so that means the PS_ON signal is not present at the power supply?
    • unicor
      • Jul 2010
      • 7
      • INDIA
      Re: Akai 40lw7
      The main board does not give the power ON voltage.
      The 24V comes if i force the power supply On.
      Thanks.
        Re: Akai 40lw7
        Do you have the service manual to be able to trace back from the pin where PS_ON is and back to the micro controller?
        • unicor
          • Jul 2010
          • 7
          • INDIA
          Re: Akai 40lw7
          No manual Sir, but i traced it back to pin 44 of microcontroller TP2808HQN.
          Any help from ur side is appreciated.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • JDC
            by JDC
            ONN 100012588
            Long answer:
            07-15-2022, 07:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
