SAMSUNG PS42D51SX bad picture
    Re: SAMSUNG PS42D51SX bad picture
    See the jumper on CN200x (can't quite read it from here)
    What happens if you move than one space across so it jumpers 3/4, I expect to see test patterns.
    • Stanislav
      • Dec 2012
      • 135
      #82
      nothing changes no test signal
        OK, we need to trace where XS and XG comes from.
        They are both generated on the control board.
        Do you see the resistor arrays like this:
        http://www.lyhen.com/img/129809421519090000.jpg
        Can you find XS on one of them and see if XG is nearby (likely same order as on the connector on the X-main.)
        Also try reversing the cable to eliminate that possibility.
        • Stanislav
          • Dec 2012
          • 135
          #84
          yes I see the resistor .XS passes through it. and goes to a small procesor
          XG also passes through this resistor and goes to same procesor
          BUT!!!!!
          resistor on XS is 47 om
          resistor on XG is 1.7k
            "resistor on XG is 1.7k"
            So, it is burnt out. You found the fault, the question is, is there a problem causing it to fail, or is it failed from wear and tear or whatever killed the Y-main in the first place. For now, I'd say jumpering across a 47 ohm resistor should be fine. You could possibly run a wire, with resistor, to the X-main, if it isn't too long.
            What was the cause of the original fault?
            • Stanislav
              • Dec 2012
              • 135
              #86
              • Stanislav
                • Dec 2012
                • 135
                #87
                I do not understand your question
                  "After damage to my TV, I changed this board which was quite damaged"
                  I interpreted this as some kind of damage was done to the TV like a power surge, is this not correct?
                  • Stanislav
                    • Dec 2012
                    • 135
                    #89
                    I have a little princess. She pressed the ON/OF button quickly two or three times .
                    I think this caused the problem with the first board "Y"
                      I'd say that's unlikely. It could have done it, but more than likely the board wore out, which is common with Samsungs, the transistors run far too hot.
                      I'd try fixing that high resistance then see if you can get a good picture.
                      This is the first time I've ever seen a signal go missing from a control board. I'm pretty surprised, but I suppose anything can happen!
                      • Stanislav
                        • Dec 2012
                        • 135
                        #91
                        when i change the resistor, will write
                        Thank you again for your time : P:
                        • Stanislav
                          • Dec 2012
                          • 135
                          #92
                          Tom Add one more to the plasma TV saved from trash
                          Many many many thanks for the help you gave me
                          I hope to have more people like you
                          Best Regards
                          • kevinm34232
                            • May 2012
                            • 1884
                            Wow, that was pretty cool Tom..
                            I have a question, which resistor was bad and how did you know the values?
                            Also what was the exact fix to the problem, did you replace the SMD resistor?
                              The bad resistor was on the control board, I believe. These resistors can be damaged by flex and shock. It is possible when the TV was removed from the stand for service that it got cracked. But that seems like a really bad coincidence!
                              The symptoms were consistent with an X-main failure and so many times simply replacing it has sorted it, well, it's not always that easy!
                              The only way we found it was by noticing the X-main output was too high, it was never being pulled low (floating around 100V), which to me indicated a fault somewhere with the XG fet. (Samsung give all switches on their X-main two-character name. XS=Sustain Supply, XG=Sustain Ground, XF=Forward ER, XR=Reverse ER, XE=Voltage Ve Bias, plus a few others I can't remember.)
                              Scoping the XS showed missing signal, so the natural question was where the signal was going missing, and it turns out, that those resistors can fail, with no apparent cause!
                              Anyway, enjoy the TV! You now have two spare X-main boards?
                              • Stanislav
                                • Dec 2012
                                • 135
                                #95
                                I cut path and put a new resistor here, damaged resistor -it bypassed
                                  Ah, so it had failed on X-main??
                                  But you replaced that board twice!
                                  Did both other boards fail too?
                                  • Stanislav
                                    • Dec 2012
                                    • 135
                                    #97
                                    No No my friend the X -bord is perfect ,There was simply more space for the X bord to installation of new resistor.
                                    Bad resistor on the other board but there is no place to bi instal new resistor
                                      OK, I suppose, you just put jumper on control board?
                                      • Stanislav
                                        • Dec 2012
                                        • 135
                                        #99
                                        Yes Tom
                                        thanks again
                                        • kevinm34232
                                          • May 2012
                                          • 1884
                                          Is that a through hole resistor you used, I cant see it? What value is it and how did you know what the values should be of those resistors?
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • ohren
                                            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                            by ohren
                                            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                            The models launched in 2018 and 2019 respectively....
                                            09-08-2023, 05:24 PM
                                          • C152Heavy
                                            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                            by C152Heavy
                                            Summary for TL-DR readers:
                                            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                            • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                            • Have read ALL applicable threads
                                            • C1818 and CP820 replaced as low hanging fruit
                                            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                            • VCC pin (18) of PFC...
                                            01-11-2023, 02:53 PM
                                          • ermals
                                            Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                            by ermals
                                            Hi all!
                                            I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                            1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                            2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                            3. I've checked voltages...
                                            08-01-2022, 10:35 AM
