SAMSUNG PS42D51SX bad picture
    Re: SAMSUNG PS42D51SX bad picture
    Can you make sure scope is set to DC on CH1? That waveform does not look right.
    • Stanislav
      • Dec 2012
      • 135
      #42
      Yes it is DC on CH1
      How to look normal signal
      UPDATE
      I put old bord in tv and is the same signal
        You should be seeing a square wave around 200Vp-p but the wave is barely 100Vp-p, and very distorted.
        It is possible it is the control board, but I really doubt it.
        Do you have good +15V to X-main?
        • Stanislav
          • Dec 2012
          • 135
          #44
          14.9v
            I really suspect the board you got is bad and has the same fault as your old one. Boards from cracked screen TVs are rarely tested. For comparison, check the YOUT on the Y-main. The YOUT will have some additional ramps on it, but otherwise should look very similar.
            • Stanislav
              • Dec 2012
              • 135
              #46
              I do not see Y OUT
              I see OUTL
                YOUT is on the Y-main.
                • Stanislav
                  • Dec 2012
                  • 135
                  #48
                  my friend I do not see this point on board Y
                    Ah, this chassis is different to the one I have been using as reference. At OUTH, what do you see?
                    If you have a second probe, it may be useful if OUTH is not ground referenced, we will find out.
                    • Stanislav
                      • Dec 2012
                      • 135
                      #50
                      2ms
                      2mikrosek
                        It looks a little better, can you try 2 microseconds on the X-main?
                        At least it is like a square wave. The scope is probably bandwidth limiting causing the ramps (instead of sudden square), I see that sometimes on my 100MHz scope.
                        • Stanislav
                          • Dec 2012
                          • 135
                          #52
                          yes but there is flickering
                            Set scope to GND, centre trace (using vertical position), then try again, does it look the same?
                            • Stanislav
                              • Dec 2012
                              • 135
                              #54
                              it seems so
                                So, it appears the XOUT is stuck at around 150V (possibly 197V -- Vsus), when it should be going from 0V to 200V. I think the X-main is definitely bad.
                                Where is the ground of the scope probe connected?
                                • Stanislav
                                  • Dec 2012
                                  • 135
                                  #56
                                  this board is declared the seller for defective, they sent another board to me, I hope next week is here
                                  Again, thank you for your time
                                  • Stanislav
                                    • Dec 2012
                                    • 135
                                    #57
                                    to the metal frame
                                      Metal frame is good for ground.
                                      I hope you can get it working.
                                      I have replaced this very same X-main board in a different Samsung plasma. It has a high failure rate. On mine it was dead short from Vs to GND, TV would not power up.
                                      • Stanislav
                                        • Dec 2012
                                        • 135
                                        #59
                                        when it's the other board come I will write again.
                                        • Stanislav
                                          • Dec 2012
                                          • 135
                                          #60
                                          Hi Tom
                                          Before 10 minutes I put the new board in TV but the problem is same.
                                          and oscilloscope displays the same VALUES
                                          Now I'm desperate
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • ohren
                                            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                                            by ohren
                                            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                                            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                                            The models launched in 2018 and 2019 respectively....
                                            09-08-2023, 05:24 PM
                                          • C152Heavy
                                            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                                            by C152Heavy
                                            Summary for TL-DR readers:
                                            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                                            • Have obtained Samsung schematic & service documents - Can upload if helpful.
                                            • Have read ALL applicable threads
                                            • C1818 and CP820 replaced as low hanging fruit
                                            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                                            • VCC pin (18) of PFC...
                                            01-11-2023, 02:53 PM
                                          • ermals
                                            Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                            by ermals
                                            Hi all!
                                            I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                            1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                            2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                            3. I've checked voltages...
                                            08-01-2022, 10:35 AM
