have jvc TV model number av20nmg3b its color is more reddish pictures and sound OK have replaced the 3 transistors at the base no Vail, the blue screen is also OK very clear no reddish on it
jvc colour issue mdl av20nmg3b
by rouninHi everyone,
I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
🛠 Original Issue
The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
by ugamazingI have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre... -
by petobongoHi, i have a LG 26LV2500 , i turned on the TV and the colors are awful, most likely solarized issue, already replaced the flex cable between board and TCON and did a reset, none of that worked.
The mainboard is a EAX64280803.
Can someone help me?
Thank you in advance. -
by shahnldGood day Experts
I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core... -
by ahmarzoHave a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
Help me to diagnose this issue as there is no shortage in the inputs MOSFET - Loading...
