Another Part Swapping Q for Vizio TVs
  • lkvee
    • Feb 2009
    • 198
    Got a Vizio L32HDTV10A from someone who tinkered with it but gave up and a VW32LHDTV20A from Freecycle.
    The L32 has a good LCD but TWO bad power boards (he bought another one but apparently that didn't help). The VW32 has a cracked LCD but has a good backlight.
    The L32 uses the LG T315XW01 V.2 and the VW32 uses the LG320WX3.
    I haven't looked inside the VW32 but if someone were to say swapping parts between these two Vizio products is no possible, I'll start the process of parting out the VW32 and work some more on the L32.
    Thanks for reading!
    Re: Another Part Swapping Q for Vizio TVs
    T315XW01 isn't an LG panel -- that's an AUO part number.
    I don't think they would be compatible as I believe the LG versions of the Vizio have the T-con on the main board and AUO versions use an external T-con which comes with the panel.
    • lkvee
      • Feb 2009
      • 198
      Thank you for clearing things up for me.
      I'll be dismantling the VW32LHDTV20A with the cracked LCD sooooon.
      Thx!
      • edugimeno
        Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
        by edugimeno
        Hi There!
        I'm trying to help my friend who owns a restaurant be just bought.
        He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
        It's stuck using, I guess, the 2 sided tape that comes with the strip
        The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
        09-05-2024, 09:34 AM
      • G-Sting
        iPad Pro A1876 SHORT Part Identify Help Needed
        by G-Sting
        So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
        So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
        i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
        SO My main concern is what part should i order what should i search the name for ?
        on Ipad...
        05-15-2025, 09:30 AM
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
      • Yanleb
        Panasonic part number in service manuals
        by Yanleb
        In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
        This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
        For an example, look at the attached PDF.
        Do you have a way to cross reference the Panasonic part number with the actual part number?
        Thanks....
        07-03-2023, 08:16 PM
