Polaroid TDA03211c
  • shorteddiode
    • 221
    Polaroid TDA03211c
    I have a standby light but it won't turn on. Can anyone tell me which wires go to the power button. Or a service manual for it?
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Polaroid TDA03211c
    If you open this up you may find two bloated capacitors near the two transformers on the power board.
      Check these two caps.
      http://s807.photobucket.com/albums/y...t=DSC01147.jpg
      • flocko
        • Nov 2012
        • 1121
        hi see my reply on opinion needed for polaroid ---
        • shorteddiode
          • 221
          It's not the caps, voltages are good, I just don't think the power button is working.
          • flocko
            • Nov 2012
            • 1121
            You will have 20v/12v/5v but the red LED will be flashing the tv will not power up.I had the same thing you need to change the two 10uf 450v caps at EC17+18 if this does not work check green fuse F2 by the big cap and if it is still not working change Q16=17 9a 500v
            • shorteddiode
              • 221
              My LED isn't flashing, Today I changed the power supply board and the main board and have the same problem. Steady red light, no clicks, no back lights. Is there another board somewhere I am missing?
              • flocko
                • Nov 2012
                • 1121
                The red LED need to be off , there is still a power board problem were did the replacement come from and did it test good ?i can only tell you the problem you have is common and the replacement of the parts i listed would fix it. Some times the led flashes other times it remains on but both indicate a problem with the board.
                • Dgtech
                  E. Technician
                  • Apr 2009
                  • 1462
                  • Steeler
                  Post the output voltages from the power board. 24V, 5V SB, 12V. Just go right down the connector.
                  The problems vary with these sets so we're gonna need more info not just swap this and swap that.
                  • tvguy12012012120
                    by tvguy12012012120
                    02-07-2025, 05:13 PM
                  • fharris1977
                    Vizio D50u-D1 Dead Set No Standby
                    by fharris1977
                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                    12-28-2023, 10:25 AM
                  • Crystaleyes
                    Samsung BN44-00259A standby question
                    by Crystaleyes
                    Hi all.
                    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                    08-11-2023, 05:15 AM
                  • psssst
                    Yamaha TSX 120 Standby Problem
                    by psssst
                    Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                    03-01-2024, 07:25 AM
                  • ChristianBr01
                    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                    by ChristianBr01
                    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                    04-23-2025, 01:48 AM
