LG 50PQ6000 went pop
  • Mr_Bodgit
    • Dec 2010
    • 47
    • doncaster
    Hi guys,
    just been reading through the 50pq6000 unstable 5v thread so im hoping Baileybum1234 or any one else might be able to check 2 voltages for me?
    The pub i DJ at has two of these and one went pop last night, done a few tv's before so figured this one would just be bad caps like most of the others
    strange thing is the psu is fine (from what i can see and on the meter)
    but the fuse has blown on the EAX60987801 (left hand board)
    the pin out from the PSU to this board is +VS, GND, +VA, GND, +5v
    when i turn the tv on after two relay clicks i get the following for a few seconds
    200vdc between the +VS pin and GND (this goes to a fuse thats blown)
    60VDC between the +VA pin and GND
    5VDC on the +5V
    a pulse like clicking can be heard from both the PSU and the EAX609 board befor the PSU shuts down probably due to no load on the +VS pin
    when you turn the tv on you get the red standby power led, press power button and it goes blue for a bit then fades away, psu needs to be left a while to reset its self
    just noticed there are 6 220uf 250v caps in the middle of this board, 3 have square edges to the top and 3 are curved and slightly taller but there all the same type of caps so i'll start there
    Regs
    Richard
    Re: LG 50PQ6000 went pop
    Can you post a picture of the suspect caps? Most likely, they are not a problem. The blown fuse on the y-sus points to some bad MOSFETs or other components. Maybe a bad buffer.
    • giggz
      • Feb 2013
      hi did you fix this problem with the tv
      because i have same tv and same problem
      would like to know what you did
      thanks look forward to a reply
      • Mr_Bodgit
        • Dec 2010
        • 47
        • doncaster
        Got a board coming this week so I'll let you know
        • Baileybum1234
          • Sep 2012
          • 245
          Just seen your post I would of checked the voltages but my PSU blew again.
          Repaired: LG50PQ6000
          • vvuk
            • Mar 2013
            • Bosnia
            Mr_Bodgit, where did you order new board for your TV? I`m having the same problem so I`d like to order it to. Thanks.
            • Baileybum1234
              • Sep 2012
              • 245
              Did it fix the problem?
              • giggz
                • Feb 2013
                For anyone whos interested i fixed this problem by just replacing the ysus board
                would like to thank (mr bodgit) for his help
                • Babbar
                  by Babbar
                  04-12-2024, 01:12 AM
                • drscoot
                  HP X360 convertible battery blown fuse error, not charging
                  by drscoot
                  HP Modelnumber: 14-dh0061nb​
                  This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                  The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                  I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                  And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                  All these 3 batteries are charging...
                  12-15-2023, 05:54 AM
                • beetle1303
                  Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                  by beetle1303
                  I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                  On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                  01-13-2025, 08:49 PM
                • jesterace
                  Samsung UE46ES8000 Blown fuse but no other signs of short
                  by jesterace
                  Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                  09-11-2024, 03:14 PM
                • whc14765
                  Gigabyte 980TI Windforce - Blown PCIE Fuse
                  by whc14765
                  Hey,
                  I have a Gigabyte 980TI Windforce. No shorts on the main 8 pin PCIE power connectors. The 8 phase buck converter inductors are showing 2.5ohms.
                  The card doesn't power up at all - no lights, no fans, nothing. I noticed that all of the 8 phase inductors are showing 0V. I couldn't find a fuse for the 8pin power connectors.
                  I did notice that the PCIE x16 connector 12V line has a fuse F3 (10A marked on it) which is blown. It is reading 16ohms on one end.
                  1st Question: Is there some logic on the board that checks the 12V on the PCIE x16 bus connector...
                  04-08-2022, 06:22 PM
