Re: LG 50PJ350-UB Power board problem
I had the experience of frying one of these a few weeks ago when I was working with the Viper22A board. Since I had fried some FETs and an IC on this board I just was not sure what else I could have damaged so I just want to be sure. I just look at it all as a learning experience about how circuits work and what I should expect to see when I probe something with my meter(s).
Apparently after you add something to an order list the link will not work for others, so I will keep this in mind in the future.
I pulled them both as you suggested and I quickly learned that I had jumped the gun on thinking one of them was bad. When I got to that point last night I was tired and it was late so the conclusions I drew were way off the mark. RL103's function is to bypass the two thermistors TH101 and TH102 when the supply comes out of standby. RL101's function is to pass the mains voltage that RL103 passed to it on to the main rectifier diode D101. When I pulled both relays and they both were open I realized the 15 ohms I was reading was the series resistance of TH101 and TH102
Thanks for the compliment, I have been trying to get better at taking pictures and I will try and highlight the areas I am describing in the future since it is helpful.
I now think the power supply is working properly. I was depending on the manual to tell me each step and I was not thinking the fluctuating standby voltage completely through. I have come to the conclusion that the voltages listed on page 42 are what you would see if you probed the pins while it was connected to the Main board. After many hours of tracing circuits, pulling and testing components it dawned on me that the reason the standby voltage was not stable was not because of a faulty component but due to a lack of load. As soon as I put a 100 ohm resistor from standby to ground the circuit stabilized at 3.434V. This is 0.2V less than listed but I do not think that is enough to be concerned about.
Since I can manually get the supply to turn on and off as described on page 41 and VA is 206.0V, VS is 60.1V and M5V is 5.1V I think it is working properly. AC Det is 4.961V compared to the 4.44 listed but this was taken with the connector disconnected and no load on the AC Det circuit which may explain why it is a little high.
I have not found a good way to probe the voltage levels between the power supply and Main board as of yet so I cannot say how far it goes to in the start-up process but no voltage is ever applied to VS. I had my meter set to hold the MAX voltage level and it never rose above ~1.5V even though I could hear the relays working. At this point I figure the best thing to do is read, research and figure out how and where to tap into RL On, AC Det, and M_ON while trying to turn the TV on so I can know how far it goes into the start-up cycle before it stops.
Thanks for taking the time to assist me in trying to figure this out, there is not doubt I have a lot to learn and need all the help I can get. Especially when I seem to cause a lot of my own problems.
As I seem to like to fry components fairly regularly.
Thanks,
Lloyd
Your link to digikey says part not found so I don't know what you are looking at.
The Fluke 77 IV can read up to 60M ohm. Without knowing the part number, I can't be sure if RL101 is bad.
Obviously, you should desolder the component (relay) and measure it out of circuit to verify.
PS. Your pics are excellent. In addition, it helps a lot when you highlight the problem area so I don't have to spend my time searching for the component. I don't have selldoor's eyesight.
Thanks,
Lloyd
