First plasma, LG 42PC5D. Sound but no picture. Help me make sense of this.
    replied
    Re: First plasma, LG 42PC5D. Sound but no picture. Help me make sense of this.
    Everything should be there for the plasma panel but it still doesn't seem to light.
  • johnboy1313
    replied
    I tried the set in the basement at night. The only light was the faint glow of the streetlight a block down coming through the window across the room.
    replied
    The top leg and middle bottom leg need to measure the same, check your probing.
    Could also be factory rework.
    Have you tried in a COMPLETELY dark room for the slightest glow... it may be very faint....
  • johnboy1313
    replied
    Well, I got the scope and found a wave at the very first point. However, I also bought some reading glasses today and found this when I put them on. I'm not sure how I missed it before. Obviously, someone's been here before me.
    I probed the pins and found.
    Top leg
    5.0V
    Bottom 5 legs from left to right
    6.0V
    3.2V
    0.0V
    0.0V
    0.0V
    Would a bad main board produce a similar "no picture" fault?
    Also because I'm inexperienced with plasmas sets, I decided to make this video. There is buzzing when I power on the unit but not like what was in the video posted earlier. You be the judge.
    http://s177.beta.photobucket.com/use...69E0F.mp4.html
    replied
    Buffer to panel.
  • johnboy1313
    replied
    Originally posted by tom66
    You just need to check a few, with the scope. If they are all missing, the buffer is at fault (possibly damaged by a bad panel but I've -never- heard of this on an LG.) But if even one is present you should see a glow from the panel, and the panel integrity might need questioning...
    I have never done this test myself but you should definitely see the ramp and sustain waveforms for all buffer outputs, each should look almost the same as the other lines.
    Thanks, I kind of expected that. I'll try to get the scope and report back this afternoon.
    Again, am I checking the pins at the SUS to the buffer or the buffer to the panel? I would guess the buffer to the panel.
    replied
  • johnboy1313
    replied
    You can check to see if each buffer line is being driven (there are test points next to each line), but be VERY careful not to short them out, or the buffer will be blown up.
    Check with the oscilloscope? Am I just looking to see that they all look similar? Am I checking at the connections from the YSUS to the buffer or from the buffer to the panel?
    replied
    The copper traces are all connected, so they are all supposed to be grounded.
  • johnboy1313
    replied
    Tom66, if I can get the scope again tonight, what am I going to scope?
  • johnboy1313
    replied
    First picture, these are the pins on the IPM from the back of the Ysus board. The pins in the yellow circle are the same pins in the yellow circle in the second pic. Of the pins in the yellow circle, they all show to be connected to ground though only the one says ground, I suspect that they are all supposed to be grounded. As for the rest of the pins, unless they say GND right next to them, there were none shorted to ground.
    However, this thing, the grey can with the red vertical stripe, whatever it is, labeled L202 on the back of the board, is shorted to ground. I have no idea if it's supposed to be or not. It's counterpart, L203 just behind it and to the right, is not shorted to ground.
  • johnboy1313
    replied
    I just read through this again. It took a second to set in. No, I didn't check the IPM for shorts. I will and will report back.
  • johnboy1313
    replied
    Originally posted by ghiotom
    Did you check the IPM on the Ysus board for shorts? The fact you aren't even getting a dim image I would think would point to the Y sus board.
    There are no blown fuses on either y or z sus. The boards both get warm when powered on and I scoped both boards and was told that the waves looked fine. Everything, except the lack of glow, suggests the ysus is working fine.
  • ghiotom
    replied
  • johnboy1313
    replied
    No, I took it back but I asked him if I could borrow it again if needed and he said that was fine.
    replied
    Do you still have the scope?
  • johnboy1313
    replied
    I started a second thread regarding scoping the ysus and zsus. For the sake of those who might have this same issue in the future, I'm coming back to this original thread. Here's the other thread.
    https://www.badcaps.net/forum/showthread.php?t=24715
    At this point, I am suspecting the y buffer board again. I know someone said that a bad y buffer would cause different symptoms, but hear me out.
    I just unplugged the y buffer board from the y sus and powered on the unit, which resulted in the exact issue as when the board was plugged in. Now I know that this doesn't confirm a bad y buffer. However, my thought is that it does confirm that the set will display the same symptoms with the buffer removed. If I had removed the board and the unit. Would no longer power up, that would suggest, at least to me, that the buffer was not part of the problem. This is promising, is it not?
  • johnboy1313
    replied
    I found a point on the y buffer that says waveform. The problem is that I have next to no idea what I'm supposed to do. I know it makes me sound really ignorant. I do have experience with a scope. I took two years of part time EET classes at the local junior college but that was at least three years ago. What am I setting the scope to? Other than the waveform point, where do I touch for the other point? CH 1 to waveform, EXT TRIG to to ground? Seriously, I can do this, but not without some guidance.
    Are any of you able to post pics to your profile? I can't even find my profile album. It's like I've been blocked or something.
  • Cosmo66
    replied
    The IPM's don't always fail short to ground. But as someone stated earlier, this is by far the most common cause of failure in the LG plasmas. The IPM's are garbage. When they fail, you get sound with no picture.
  • Cosmo66
    replied
    Originally posted by johnboy1313
    Wouldn't there be blown fuses if something was shorted to ground? Both y and z sus boards get warm to the touch when the unit is powered on.
    Probably but not always
  • LEECH666
    Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
    by LEECH666
    Good day ladies and gentleman!
    I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
    This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
    I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
    01-19-2024, 05:46 PM
  • KYBOSH
    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
    by KYBOSH
    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
    No picture but you hear the TV static (white noise) playing loud and clear.
    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
    But it seems they didn't get too far and just left it.
    When I first took a look I was amazed at how pristine the inside looked.
    Its as if the TV had been in a time capsule.
    Caps looked like they were just pulled off the self.
    Copper coils had no sign of corrosion on...
    02-01-2023, 11:10 PM
  • SluggerB
    LG Plasma (PDP50R10101) No picture No sound
    by SluggerB
    This is my first Craigslist freebie fix attempt. 50 inch LG Plasma TV Previous owner said over time it was struggling to turn on, it would take 4-5 times to turn on, the one day it just did entirely. I took it home and plugged it in, I her a click, then a second later another click, and nothing. Dead as a doorknob
    So I took the back off and check voltages. The power supply appears fine, I checked the VS, VA, and 5V voltages and they all measured correct, on the power supply board and on the display boards (Y and X boards). All the fuses are fine
    Following a YouTube videos...
    12-03-2022, 09:10 PM
    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500 Specification for Upgrade or Repair
    This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-12-2024, 02:30 PM
    HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
