Vizio HDTV20A Y-main JL41-04217A
  • lrowell
    • Nov 2012
    • 3
    I was wondering if someone could tell me what the values are for the two resistors in the picture I found in the forum, they got really hot due to a shorted upper buffer board and I am not sure of the color bands. All other parts test good.
    Re: Vizio HDTV20A Y-main JL41-04217A
    Are there any for the lower buffers? Most likely, they will be the same.
    • lrowell
      • Nov 2012
      • 3
      No, there are no others that are similar. These two are located in the center of the board between the two buffer board connectors.
        I do recall someone else having this problem.
        I found this hires picture of a working board:
        http://futuregatetech.com/Websites/f...d5a7eee21d.JPG
        But I still can't be sure on the value :/ Maybe brown black black gold which would make it 10 ohms 5%, looks to be about 3W.
        • tw2005
          • Oct 2011
          • 6458
          http://www.shopjimmy.com/samsung-bn96-06519a-y-main.htm
          This shot is also pretty good
          Looks brown,blk,blk gold
          No shorted 88n30W FETs?
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
          • mrtek
            Vizio M65-C1
            by mrtek
            Hi.
            picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
            When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
            This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
            07-14-2025, 07:28 PM
