samsung pn50a450 blank screen issue no sound
  • jettboat
    • Nov 2012
    • 63
    Help needed! I've got this samsung turn it on makes the start up noise, have all voltages vs 208v , va 56v, 5.2v , 15v , 3.2v at y sus, z sus o-scoped at the y sus have the signal there, tested y sus ic no short fet's fuses ok etc. on this tv the buffers & y sus are one board # pcb lj41-05308a . but suspect it to be the issue as the heat sinks do not get warm at all but still have voltage ? psu is good not shutting down. did replace a blown up Triode Transistor mr4710 @ location u5701 next to cn5801. I cant post pic yet no com with me. I dont want to just buy a y board to test it like to go componet level if possable. the screen being bad not likely
    thanks for any help jett
  • jettboat
    • Nov 2012
    • 63
    Re: samsung pn50a450 blank screen issue no sound
    I just ordered a y sus / buffer for it $50 on e bay will see if this gets it going hopefully!
    • jettboat
      • Nov 2012
      • 63
      tv is fixed was the y sus / buffer on to the next broken one
        Nice fix. Thanks for posting the fix.
        • Kjell
          Samsung Series 9 - BIOS issue
          by Kjell
          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
          08-01-2025, 09:15 AM
          09-07-2024, 05:50 AM
        • benspawn02
          Anthem MRX500 - no sound. R2A15218FP issue??
          by benspawn02
          Dear Electronics Experts:
          I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
          08-12-2023, 04:46 AM
        • ctebke
          DELL 3501 MB la-k034p Sound issue
          by ctebke
          Hello, I have dell 3501 MB la-k034p with Sound issue RED cross. No sound device in device manager. In BIOS diagnostic everything passes but no sound tone either in bios test. AUDIO chip is CS42l42 and 3.3v, 1.8v is present. Someone have any idea ? Thanks.
          Today, 08:09 AM
        • Nairolf
          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
          by Nairolf
          I have a Samsung DM32D display.
          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
          Here’s what I have tried so far:
          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
          From these tests, I suspect the problem might be on the mainboard. Could anyone...
          08-24-2025, 03:47 AM
