samsung pn50a450 blank screen issue no sound
  • jettboat
    • Nov 2012
    • 63
    Help needed! I've got this samsung turn it on makes the start up noise, have all voltages vs 208v , va 56v, 5.2v , 15v , 3.2v at y sus, z sus o-scoped at the y sus have the signal there, tested y sus ic no short fet's fuses ok etc. on this tv the buffers & y sus are one board # pcb lj41-05308a . but suspect it to be the issue as the heat sinks do not get warm at all but still have voltage ? psu is good not shutting down. did replace a blown up Triode Transistor mr4710 @ location u5701 next to cn5801. I cant post pic yet no com with me. I dont want to just buy a y board to test it like to go componet level if possable. the screen being bad not likely
    thanks for any help jett
  • jettboat
    • Nov 2012
    • 63
    Re: samsung pn50a450 blank screen issue no sound
    I just ordered a y sus / buffer for it $50 on e bay will see if this gets it going hopefully!
    • jettboat
      • Nov 2012
      • 63
      tv is fixed was the y sus / buffer on to the next broken one
        Nice fix. Thanks for posting the fix.
        • Kjell
          Samsung Series 9 - BIOS issue
          by Kjell
          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
          08-01-2025, 09:15 AM
          09-07-2024, 05:50 AM
        • benspawn02
          Anthem MRX500 - no sound. R2A15218FP issue??
          by benspawn02
          Dear Electronics Experts:
          I have the following problem I am trying to troubleshoot. Unfortunately, I have contacted Anthem themselves and even a local distributer but I am not having much luck. Also, I have scoured the internet and unable to obtain a service manual. The Anthem service rep has also replied that he is unable to provide me with any service documentation. I have performed numerous searches on the internet and cross-referenced a few other AV receiver makers (Denon, Marantz, Onkyo) and found certain similarities to block diagram...
          08-12-2023, 04:46 AM
        • Nairolf
          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
          by Nairolf
          I have a Samsung DM32D display.
          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
          Here’s what I have tried so far:
          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
          From these tests, I suspect the problem might be on the mainboard. Could anyone...
          08-24-2025, 03:47 AM
        • vincentedel
          Samsung SyncMaster 740n Phase Control Issue
          by vincentedel
          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
          04-22-2025, 12:33 AM
