Emerson LC401EM2F
    Re: Emerson LC401EM2F
    SA1601 is OK so the fuse is not seeing a dead shorts. How are the the Diode second set of the rectifier (D1607~1609)?
    "c1612 on my blue esr meter it shows .33 in the board and on my dmm on the 20M setting it starts at 2.2 and then goes down" how far down does it go down to?
    • Mark369
      • Jul 2009
      • 163
      would it only be a short to ground that would make the main fues blow?
        Shorts between rails would also blow the fuse, but they are rarer.
        Shorted diodes could do it sometimes.
          I would use a 100W lamp place in place of the fuse to see if it glows brightly (no need to turn the power switch on).
          Or make one like this:
          http://s807.photobucket.com/albums/y...t=DSC01681.jpg
          http://s807.photobucket.com/albums/y...t=DSC01682.jpg
          http://s807.photobucket.com/albums/y...t=DSC01679.jpg
          • Mark369
            • Jul 2009
            • 163
            so would i be looking for a short on the hot side only or anyware on the board
              Both sides since you may also have bad rectifiers, MOSFET, etc. Did you try using lamp yet?
              • Mark369
                • Jul 2009
                • 163
                #27
                no have to get some stuff to set it up.
                I had one fuse laying around and just tryed it and opened as soon as i pluged it in.
                fuses 3.00 a pop.
                • Mark369
                  • Jul 2009
                  • 163
                  #28
                  oh yea and i tested on cold side ground to jumper wire J1114 labled RL + 5.0V and there is 47.2 ohm to ground if that means any thing. J1114 is connected to R1214 and D1215.
                  i know D1215 is with the relay RL1201 would that make it look shoted.
                  Thank you for your time. will post back soon.
                  • Mark369
                    • Jul 2009
                    • 163
                    #29
                    https://www.badcaps.net/forum/showth...rson+lc401em2fI read this post before I started this one.
                    It's the same board same every thing. this tv is only 12 months old.
                    so you could use his pics same board no damage can be seen not even heat spots.
                    • Mark369
                      • Jul 2009
                      • 163
                      #30
                      any one know if im on the right track?
                      • Mark369
                        • Jul 2009
                        • 163
                        #31
                        Bump
                        • Mark369
                          • Jul 2009
                          • 163
                          #32
                          anyone?
                          • Mark369
                            • Jul 2009
                            • 163
                            #33
                            I think that it has a shot on 5.0v rail to ground but not sure how to find it yet.
                            I have a muilt-meter and a blue esr meter i have a 15Mhz scope but i don't know very much about the scope on how to use. don't think i could use it if there is no power on the board anyways.
                            could some one give me a hand to find short.
                            thanks and mary christmas to all
                            • Mark369
                              • Jul 2009
                              • 163
                              #34
                              I removed sa1601 and it looks like it's open no readings on diode setting or on any other setting
                              I removed d1201 to d1204 all ok.
                              I still think there is a short on 5v rail to ground but would like some help finding it
                              • Mark369
                                • Jul 2009
                                • 163
                                #35
                                Maybe q1201 or q1202
                                • Mark369
                                  • Jul 2009
                                  • 163
                                  #36
                                  • Mark369
                                    • Jul 2009
                                    • 163
                                    #37
                                    I was checking things and found I have short on pins of T1201 its like pins 5, 6, 7, 9, 10 are all connected together and pins 1, 2, 3, 4 all connected together. I have not removed yet to retest.
                                    IC1201 (MIP2F30MSSCF DIP7-A1) same thing pins 5, 7, 8 all connected? pins 1 to 4 all connected? short on c1208?
                                    have not removed yet to retest. found datasheet but not in english.
                                    how would i check the transformer and no i don't have a ring tester
                                    • Mark369
                                      • Jul 2009
                                      • 163
                                      #38
                                      i must be on my own now no on saying anything last 10 post all mine
                                        OK, we need to start isolate the circuits to find out which section is shorted out, let try removing the Q601 (2SK3798) on page 3. You should use the lamp (100~200w) in place of the fuse so you will not keep blowing fuses and cause more damages.
                                        • kevinm34232
                                          • May 2012
                                          • 1884
                                          bud with that lamp tester you have, did you have to make the box with the lamp holder and on/off switch, or did you buy it like that?
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • jesterace
                                            Samsung UE46ES8000 Blown fuse but no other signs of short
                                            by jesterace
                                            Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                            09-11-2024, 03:14 PM
                                          • jshhh
                                            Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                            by jshhh
                                            Hi guys,
                                            I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                            How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                            Anybody know how to remove this type of fuse?
                                            (The fuse is toward the bottom of the image labeled F2)...
                                            06-17-2025, 01:35 AM
                                          • Babbar
                                            by Babbar
                                            04-12-2024, 01:12 AM
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
