Toshiba 26HF85 Power Problem
    My Toshiba 26HF85 worked fine last night. I turned it off, went to bed. After work today, I tried turning it on. The red power light illuminates for approximately a second, then powers back down without any sound/picture? I've searched the forums for any posts on my TV, with no luck. I've tried the usual unplugging for 10 minutes, removing any remotes from the area, with no results. Any possible causes, or possible solutions? Any help is greatly appreciated.
    Jallopy
    Re: Toshiba 26HF85 Power Problem
    Hate to state the obvious but the set has failed.
    Whats good is that the warrenty is a yr and two on the tube.
    If you bought it with a card you may have double that.
    Jim
      Figured as much, but I had to try. I've only had the thing since March, so at least it's still under warranty. Thanks for the reply.
      Jallopy
