Hitachi AV Receiver, victim of dog pee!
    Quick video showing diagnosis:
    http://www.youtube.com/watch?v=e3U-jWT0xu4
    Dog pee caused the bridge rectifier to short on the standby part of the primary side, blowing the mains fuse.
  • mariushm
    • May 2011
    • 3799
    Re: Hitachi AV Receiver, victim of dog pee!
    tom, if that's your channel, I don't see why you bother uploading in 720p - it's obvious that camera isn't capable of that. Lightning is also crap.
    I'd recommend getting a used camera off eBay if you're serious about making tube videos, there's some very nice low light sensor cameras there.
      My channel. Youtube did the scaling -- my camera outputs 640x480 VGA at a full 30fps. I guess it makes it widescreen by converting it to 720p.
      For the videos I edit, my video editor outputs 720p because it makes text and images clearer.
      When I get the time or money, I will, but for now I'm stuck with my camera. (Nikon Coolpix 7600) The video really lacks on it, but it takes fantastic macro pictures for a compact.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        some good videos on there tom and some good tips keep the guides coming ideal for a newbi like me
          Additionally, I found a 33 ohm resistor on the PSU had failed -- it's the big ceramic one, R419 I think. It's a common failure on these PSUs apparently, not sure whether the dog pee made it worse?!
          • CdDvdFlash
            Hitachi HTA-DD3W AV Receiver Error Code -Protect-
            by CdDvdFlash
            I have a Hitachi HTA-DD3W AV receiver and when I got it I tested it working fine with speakers but it needed a clean inside because it had signs of moisture in it but it was fully dry with bits of wood chips, I guess this was left in a shed so I fully disassembled it and cleaned it with isopropyl alcohol very carefully, some de-soldering was also needed but now its very clean, luckily there was no rust on any components and all the capacitors are fine with no bulging. When I turn it on I hear a relay switch on then a few seconds later another relay switches on or off and the display has a "-PROTECT-"...
            07-10-2023, 06:05 AM
          • Jaime Morillo
            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
            by Jaime Morillo
            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
            The TV was stuck on the logo and I couldn't access the update menu.
            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
            The image result was good, but the image is inverted.
            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
            08-18-2025, 11:38 AM
          • CDNBrewer
            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
            by CDNBrewer
            Hello Everyone,
            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
            Symptoms:
            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
            • I swapped the Left and Right surround
            08-05-2025, 09:29 PM
          • wolf1976
            wireless receiver for 6 speeds fan control with remote control
            by wolf1976
            hi i have a receiver that is destroyed from the overvoltage i guess
            my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
            the motor fan has not label
            i have an other receiver operational
            In your opinion can i measure the voltage at the output ?
            what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
            thanks in advance...
            07-23-2025, 03:12 PM
          • rddube
            Help with blowing transistor NAD T752 receiver
            by rddube
            I guess I need help from the masters to try and find what is frying a 2SC5669 transistor on the left channel of this front center Amp for a NAD T752.
            Was working perfectly and all of a sudden I heard a pop, and then a glow from the amp. Not only did the 2SC5669 burn a leg, but R520 which is a 220 ohm resistor partially burned - it now measures 110 ohms.
            I bought this amp second hand fairly cheap as it was not working, it went into protection mode. I finally traced it down to the same transistor Q510, the one that just popped. It was shorted...
            09-01-2022, 05:19 AM
