I attempted my first TV repair and got close, but no cigar... and I'm not sure where to go next.
The unit is a Sceptre X32 LCD TV and originally would not power up at all. It had 4 CapXon capacitors, two leaking/bulged, so I replaced all 4 with nichicon HE equivalents. The rest of the capacitors look OK, but I do question the large blue capacitor (filter cap?) as it feels like it could be slightly bulged, but I'm unsure and I don't have a capacitance meter.
After the repair, the unit does power up and displays the logo, but after about 4 seconds, the unit powers downs completely. No output voltage from the power supply at all. The unit will also not power up again until it has been disconnected from the mains for about 30 seconds (the time it takes for the indicator light to go dead).
In the photo of the power supply:
Connector "A" goes to the control board. It has 3 5v, 2 12v, 2 24v and 3 ground leads.
Connector "B" goes to the inverter board. It has 5 24v and 5 ground leads.
There is also a 2 wire feed from the inverter board (on the same connector as from the power supply) to the control board on its own connector (red and orange).
Green dots are the caps I replaced.
When first connected to the mains, the indicator light starts blue then to red (normal - TV not on).
On connector "A", all voltages are correct for about 4 seconds then fall to 0v except for 1 5v lead that remains active. Also note; the other two 5v leads first drop to about 2.1v then slowly to 0v.
On connector "B" all voltages are steady and correct for about 4 seconds and then fall to 0v.
The two leads from the inverter board to the control board read 3.5v for the 4 seconds then falls to 0v.
When the unit is then powered on with the power button, all voltages come back to specs but after the back light has been on for about 4 seconds, all output voltage is lost.
I have also tested the unit with the inverter board disconnected at the power supply, but with the two leads from the inverter board to the control board still connected, with the same results.
I'm just not sure if this is the power supply failing or if the control board is issuing a power supply shutdown - or how to test.
Thank you all.
Kevin
Thank you all.
Kevin
