Vizio e421vo
  • Salvamex
    • Nov 2012
    • 48
    Vizio e421vo
    Hello, I am new to this forum so please bare with me.
    I am also new to electronics.
    I have a E421VO Vizio tv that is not working.
    I already changed the power supply and the main board with no luck.
    all it has is the orange light but nothing happens when i push the on button on the tv or the remote.
    I checked with the multimeter on the power supply and I get 5v on the stanby mode.
    Please help.
    Thank You.
  • drpj23
    • May 2012
    • 528
    Re: Vizio e421vo
    Does the part number on the main board match the one you replaced?
    • Salvamex
      • Nov 2012
      • 48
      Re: Vizio e421vo
      yes, everything matched. i found a thread here that says to replace the eeprom.
      I found eeprom but now I wonder what solder gun to use and what kind of solder if there are different kinds.
      do you know?
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        03-31-2024, 02:12 PM
      • smalltownguy
        Vizio E421VO - will not power on
        by smalltownguy
        Was gifted a 42" Vizio LCD TV, model E421VO. Will not power on. DOA. No activity. Checked power cord, it's good. Checked remote, it's good. Here's some pics. Where to start?...
        05-06-2025, 08:22 AM
        07-01-2024, 06:34 AM
      • CMCM
        Russound CA4 Power Supply Repair
        by CMCM
        Hello Everybody,
        Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
        Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
        The outputs marked 12v and 20v are all measuring only 1v.
        The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
        The capacitors physically look clean (no bludgesor leaks) and...
        07-03-2025, 01:12 PM
