Panasonic TCP42S2 worth getting?
+ More Options
Posts
  • IamCanadian
    • Nov 2012
    • 119
    This is the problem described.
    "Don't think it is the panel. Before it completely quit working we were able to get it to power on after pushing the power button a dozen times or so. The remote would work as well after a few tries. So w e could use it
    , after while it was taking too many tries. Each time you push the power button it takes a few seconds to cycle on so we lost patience. Have tried a few times since and it will not power on.
    So the panel was fine. Just seems to be something to do with powering on"
    Sounds like ps or main board to me.
    Re: Panasonic TCP42S2 worth getting?
    I thought you had it already? Sounds like PSU to me. If it blinks 2, 4 or 10 times, it's the PSU.
    • IamCanadian
      • Nov 2012
      • 119
      he said it only blinks once, If I want it he will drop it off today...just dont have alot of room left for tv's lol
        One blink is A board usually, but sometimes "No particular check point" which could be troublesome to track down.
        • Andre Gilbert
          by Andre Gilbert
          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
          11-20-2024, 08:52 PM
        • AquaMan Ua
          Problem with PANASONIC CF53 laptop after changing BIOS settings
          by AquaMan Ua
          Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
          05-17-2025, 09:40 AM
        • aa10aa10
          Panasonic Toughbook CF-33 mk1 BIOS repair
          by aa10aa10
          Good day,
          I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
          I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
          01-21-2025, 06:13 AM
        • Mnawar27
          Panasonic CF-H2AU24EF3 bios locked
          by Mnawar27
          Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
          I need help to remove it,
          thankyou all.
          SN; 2FKCA26876...
          11-16-2024, 08:00 AM
        • Yanleb
          Panasonic part number in service manuals
          by Yanleb
          In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
          This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
          For an example, look at the attached PDF.
          Do you have a way to cross reference the Panasonic part number with the actual part number?
          Thanks....
          07-03-2023, 08:16 PM
