Hey all I'm still new but I have a 55" Samsung tv model: HP-S5053. I recently got this tv for cheap and it was black screen with sound and power. After replacing 3 caps I powered it on only to see all dark static with a few vertical black lines on the right side. I was first told it was probably a faulty x-sustain so I bought a brand new one in efforts to fix it. After putting the new one in I was left with the same static and black lines only seemed worse with a black blob in the middle now. After hours of research I found that ther problem could be caused by bad drivers? Ive taken off the main board for the pics but ive attached many pictures hoping that it will help you give me any advice. For starters I don't even know where to find the drivers. Please help, this tv will not get the best of me! Thanks in advance. Last pic is what it looks like now
Samsung Tv vertical lines No Display
Re: Samsung Tv vertical lines No Display
Why did you create a new thread? Try and keep everything in one thread...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by FalkiHello there, ive recently found an older 55inch Samsung SmartTV.
A similar issue has been posted as well but also with no actual response ...6 Photos -
by arctorhi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...2 Photos
by rfxcaseyI have an Siemens HMI with vertical lines on half of the screen. These lines aren't scrambled garbage but rather very regular in pattern and color. I have replaced the LCD with a new one and still the problem persists. I'm wondering if this isn't indicative of a bad video process chip or video memory? Any help would be appreciated. The cable appears to be OK but one pin on the header is unpopulated, though there isn't any loose wire to suggest one broke off or popped out of the connector. In the picture below where the connector is busted out of the side, I did that with my small screw driver...
05-16-2024, 06:52 AM -
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
- Loading...
