LG 42PC1DA Plasma Sound but blank screen
    Re: LG 42PC1DA Plasma Sound but blank screen
    That is usually normal. The buzzing is like this
    https://www.youtube.com/watch?v=-iAm82lhky4&t=1m08s
    • LesWoollam
      • Nov 2012
      • 69
      • United Kingdom
      #62
      The buzzing I'm getting is the same but a lot quieter.
        Hmm, makes me wonder if the panel is bad.
        • LesWoollam
          • Nov 2012
          • 69
          • United Kingdom
          #64
          Looks like this one's destined for the skip
            Just to make sure, is the buzzing skipping the occasional beat or changing frequency occasionally like it does in the video, or is it continuous?
            • LesWoollam
              • Nov 2012
              • 69
              • United Kingdom
              #66
              It's continuous.
                That might be normal buzzing from the Y or Z-sustain, it's usually very loud when the panel is cracked.
                • LesWoollam
                  • Nov 2012
                  • 69
                  • United Kingdom
                  #68
                  That's what I initially thought but it does sound exactly the same as the buzzing on the video you linked, just a lot quiter. Now I'm confused. . .
                  • pawel125
                    • Nov 2013
                    • us
                    #69
                    hello Any ideas?? bed screen ??- module work ok i have big bum and show the picture
                    • mecha1166
                      KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                      by mecha1166
                      KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                      11-25-2024, 05:22 PM
                    • mrtek
                      Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                      by mrtek
                      Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                      11-26-2024, 09:58 AM
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • triplefour
                      TCL 65S403 Blank Backlit Screen w/ sound ... voltage besides 12v missing at LVDS
                      by triplefour
                      Blank Backlit Screen w/ sound verified via DVD on HDMi 3
                      no change to display when disconnect tcon
                      no change to display when disconnect panel cables (both sides, one at a time, etc-)
                      can faintly see a vertical dividing line splitting the panel even in half. super faint tho.
                      also can faintly see a black cloud in the center of the screen. a darker area.
                      color of screen is backlit black screen which basically looks gray
                      12v present at TCON fuse
                      other voltages on LVDS cable (TCON side) are missing. only see 2 pins with voltage .69v and .60v
                      10-28-2021, 01:00 AM
                    • Rozp
                      70LE660U dark cloud or black screen with sound.
                      by Rozp
                      Hello Everyone,
                      This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                      I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                      08-29-2023, 05:25 PM
