LG 42PC1DA Plasma Sound but blank screen
    Re: LG 42PC1DA Plasma Sound but blank screen
    That is weird, I do not expect that ramp type wave on the Z-sustain, is that with power connected to the Z-sustain?
    • LesWoollam
      • Nov 2012
      • 69
      • United Kingdom
      Everything is connected to the Z-sus board.
        I think somehow the Y-sus signal is getting to the Z-sus, and the Z-sus is not working.
        • LesWoollam
          • Nov 2012
          • 69
          • United Kingdom
          Could it be that the 15v supply voltage from the Y-sus is not getting to the z-sus board?
            That could be a cause; did you check it?
            BTW, I should have said I think the Y-sus signal is just being picked up on one side because the Z-sus is essentially open circuit and your scope doesn't represent signficant load.
            • cliff_hootarski
              • Jul 2006
              • 411
              Quick question I've been meaning to ask and this is related to this thread.
              Does the O-scope need to be isolated through an isolation transformer?
                No, that is only necessary if you are measuring the mains/primary side of the PSU.
                • LesWoollam
                  • Nov 2012
                  • 69
                  • United Kingdom
                  #28
                  15v good coming out of the Y-sus board and going into the Z-sus board.
                    Is there a fuse on Z-sus for 15V?
                    • LesWoollam
                      • Nov 2012
                      • 69
                      • United Kingdom
                      #30
                      There doesn't appear to be a fuse for the 15V supply.
                      I've noticed that only D14 temperature LED on the Control Board lights even from cold power-up. This does not appear to agree with the sequence suggested in the attached diagram. Could this have anything to do with the problem?
                      • LesWoollam
                        • Nov 2012
                        • 69
                        • United Kingdom
                        #31
                        I've removed both the Y and Z-sus boards and performed diode tests on the IPMs.
                        The Z-sus IPM seems to check-out OK, but the Y-sus IPM reads an open circuit between pins VS & VER1 and VS & VER2. Does this indicate a fault which would cause a blank screen? What are Pins VER1 & VER2?
                          VER1 and VER2 must not be shorted together, so I think your Y-sus IPM is OK.
                          • LesWoollam
                            • Nov 2012
                            • 69
                            • United Kingdom
                            #33
                            According to the manual, there should be a diode reading between "VS and VER1" and also between "VS and VER2". I don't get a diode reading between those pins, instead it reads open circuit.
                              I assume you've tried both directions?
                              Your Y-waveform is correct with the sustaining and ramps. The Z-waveform should not have any ramps in it at all.
                              Can you try measuring the Z-waveform without the Y-sustain connected, and the Y-waveform without the Z-sustain connected? This should eliminate cross-contamination, as such.
                              • LesWoollam
                                • Nov 2012
                                • 69
                                • United Kingdom
                                #35
                                I'll measure those in the morning and verify the traces.
                                • LesWoollam
                                  • Nov 2012
                                  • 69
                                  • United Kingdom
                                  #36
                                  Y-sus trace with Z-sus board removed.
                                  Z-sus board will not power-up without 15v supply from Y-sus board (therefore no trace).
                                  I've attached another Z-sus trace with all boards plugged-in.
                                  Any more thoughts?
                                    Which is Z-sus, and which is Y-sus?
                                    I suspect your Z-sus is faulty.
                                    • LesWoollam
                                      • Nov 2012
                                      • 69
                                      • United Kingdom
                                      #38
                                      Z-sus tace is the one on the left.
                                      Are there any more tests I can do on the Z-sus to confirm it's faulty?
                                      Every component on the board remains cold but the voltages all check-out OK and the diode test readings on the IPM all look fine.
                                        Can you post a clear picture of it?
                                        • LesWoollam
                                          • Nov 2012
                                          • 69
                                          • United Kingdom
                                          #40
                                          Pic of Z-sus board attached.
                                          • mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                            by mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                            11-25-2024, 05:22 PM
                                          • mrtek
                                            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                            by mrtek
                                            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                            11-26-2024, 09:58 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • triplefour
                                            TCL 65S403 Blank Backlit Screen w/ sound ... voltage besides 12v missing at LVDS
                                            by triplefour
                                            Blank Backlit Screen w/ sound verified via DVD on HDMi 3
                                            no change to display when disconnect tcon
                                            no change to display when disconnect panel cables (both sides, one at a time, etc-)
                                            can faintly see a vertical dividing line splitting the panel even in half. super faint tho.
                                            also can faintly see a black cloud in the center of the screen. a darker area.
                                            color of screen is backlit black screen which basically looks gray
                                            12v present at TCON fuse
                                            other voltages on LVDS cable (TCON side) are missing. only see 2 pins with voltage .69v and .60v
                                            10-28-2021, 01:00 AM
                                          • Rozp
                                            70LE660U dark cloud or black screen with sound.
                                            by Rozp
                                            Hello Everyone,
                                            This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                                            I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                                            08-29-2023, 05:25 PM
