LG LCD 47lg50 screen issues
  • Rcgui
    • Nov 2012
    • 7
    • United states
    I posted about this earlier this week, but This time I have more info about it. As stated its a 47lg50 and the screen goes off after about a half hour however the backlight and audio stay on just the image goes off.
    What I've tried:
    1. I tried running it without the back cover and with 2 fans blowing on it, and it ran for about three hours, but then I had to shut it off because I was heading to bed. Every component on the back was cold to the touch
    2. I tried the same thing with out fans and it did get warmer but it stayed running for about the same time, and the I shut it off because I had to go
    Any ideas on what could be overheating? I am thinking about installing one or two computer fans in the back to assist in cooling and maybe making some vents on the back cover bigger. The fans I thought would help also to keep the overall temperature down, which might help everything last longer. I don't want to start replacing things if I don't know what it is, so any ideas can help. Also I didn't see any bulging or leaking caps on the psu though they still could be bad, if that helps at all.
    Thanks,
    Rcgui
  • tibimakai
    • Jan 2012
    • 3680
    Re: LG LCD 47lg50 screen issues
    My last Philips TV that I have repaired, the T-con was overheating. I have found a nylon layer on top of the heat pad, which in my opinion it should not have been there.
    I have installed a Pentium CPU heatsink on the shield and it worked great closed in a garage when the temperatures were over 100.
    I have even left it 24 hours to run and it was still fine.
    • Rcgui
      • Nov 2012
      • 7
      • United states
      Thanks for the reply!
      Do you think it would be fine it would be fine if I just put a few fans in? Because I'm thinking that if I keep the temperature low it should be fine.
      Any thoughts?
      Rcgui
        It would most likely be delaying the problem -- adding a heatsink would be similar -- but if it delays it long enough to last 5 years it could be a good fix.
        • Rcgui
          • Nov 2012
          • 7
          • United states
          I was thinking of taking it into a shop to see if they could diagnose it, but if fans could keep it cool it would seem that it would do the trick.
          Do you have any idea what component it might be?
          Thanks,
          Rcgui
            A TV repair shop would charge you $100 for diagnosis and then $200 to get a new board which would only die in a few years' time. At that price, you could seriously consider a new 42" plasma (even though I don't like the low end offerings from Samsung or LG, they would likely last you 3-5 years.)
            Try the fans. The worst is it won't solve the problem.
            • Rcgui
              • Nov 2012
              • 7
              • United states
              I think it should work, when I had the fans on it before everything was cold to the touch, and heat would wear it down faster.
              Have any of you tried fans before?
              Rcgui
                No, I have never bodged fans into a design that didn't originally use them.
                • Rcgui
                  • Nov 2012
                  • 7
                  • United states
                  Im going to try to get some fans today and hopefully mount them. I will post pics when I'm done
                  Rcgui
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • aazjo
                    A1502 screen only issues
                    by aazjo
                    I have a MBP A1502 (early 2015, 820-4924) with a screen that will not turn on. I have swapped screens with a cracked test screen and the computer boots and the cracked screen works for both backlight and image. The black/blank screen appears to do nothing.
                    I have collected resistant data from the cracked screen connector pins and submitted to OBData server:
                    1 PPVOUT_SO_LCDBKLT OL
                    3 I2C_BKLT_SCL 9.97M
                    4 I2C_BKLT_SDA 9.89M
                    5 PP3V3_S0_EDP_R 79.10k
                    6 SMBUS_SMC_0_S0_SCL 321k
                    7 SMBUS_SMC_0_S0_SDA 323k
                    8 EDP_BKLT_PWM ...
                    11-04-2021, 11:46 PM
                  • nejib01
                    Asus et2002t touch screen issues
                    by nejib01
                    Hi , i get an old Asus et2002t touch screen , everything go good but i have geometric surfaces not responding touch (red colored bad surfaces , see image uploaded) , any help
                    Thank you in advance...
                    09-09-2025, 09:13 AM
                  • emil_t
                    RTX3090 working fine but fans not spinning
                    by emil_t
                    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                    04-12-2024, 06:54 AM
                  • cloo
                    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                    by cloo
                    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                    After doing a factory reset this problem was gone and the picture was back to...
                    01-06-2025, 06:02 AM
