Sansung fp-t5084 black vertical lines, other issues
  • jimmy2
    • Nov 2012
    • 5
    • usa
    Samsung fp-t5084 plasma, picture went out and found many bad caps on the power supply. Pulled and replaced the caps. Powers up but no picture. Replace y-main and both upper and lower buffer boards and tv has a picture with two vertical black lines on the left side. Read it could be a connection or a bad f-address board. Picked up a cheap f-address board and as soon as it powered up 5 22ohm resisters fried. Still have the same two black lines. Can the power supply still be an issue or maybe the x-main? Can the panel be bad? Any help would be greatly appreciated.
    Thanks Jim
  • jimmy2
    • Nov 2012
    • 5
    • usa
    Re: Sansung fp-t5084 black vertical lines, other issues
    Any thoughts on this issue. I don't want to give up!!
      Possibly a bad panel...
      • Cosmo66
        • Nov 2012
        • 87
        I have one of these models I'm working on right now. After doing some research online, it sounds this model in particular is plagued with many problems. I found blown caps all over the y sustain and power supply. I've replaced almost every single one. I'm ready to huck the thing out the window
        • Cosmo66
          • Nov 2012
          • 87
          Have you checked the connectors to the panel?
          • jimmy2
            • Nov 2012
            • 5
            • usa
            I have released and pulled out the ribbon cables on the board where the black bars are appearing. They seemed to be secure. I just dont understand why a replacement board would have 5 resisters burn up as soon as power up. Im thinking of replacing the resisters and powering the set up with the panel connectors unplugged to see if the resistors still fail. Could a bad panel maybe cause the board to fail??
              If the driver IC in the flex is shorted, it could cause that.
              • jimmy2
                • Nov 2012
                • 5
                • usa
                anyway to tell if a driver ic is shorted??
                  Not 100%... but generally when you have single pixel lines or blocks about 4cm wide, it's the panel. The F-address has very little on it which can fail, usually it causes the whole half or third of the screen to fail.
                  • jimmy2
                    • Nov 2012
                    • 5
                    • usa
                    I have two complete black approx two inch wide vertical lines out
                      Yeah, that looks like a panel failure to me. It could be a loose driver connector, but it seems more likely to me that it's a bad panel.
                      Note: If the 5V on the PSU went too high due to bad caps, it could damage the panel.
                      • Stanley1843
                        by Stanley1843
                        06-29-2024, 11:54 AM
                      • Falki
                        Colorful LCD Vertical Lines on Samsung ue55es8090
                        by Falki
                        Hello there, ive recently found an older 55inch Samsung SmartTV.
                        A similar issue has been posted as well but also with no actual response ...
                        08-12-2025, 04:19 AM
                      • visionbluedemon
                        Help. Sony kd-65x85dj vertical lines
                        by visionbluedemon
                        First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                        Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                        tried blocking LC lines too, but same results
                        is it lcd panel issue or tcon board issue?...
                        07-25-2025, 04:56 AM
                      • gpo23
                        Sony KDL-40V3000 - Vertical lines
                        by gpo23
                        i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                        With the new t-con the color are good but there are vertical lines on all the screen :
                        I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                        Is there a way to fix the vertical lines on the new t-con ?
                        Thank you for your help
                        gpo23...
                        10-04-2023, 09:11 AM
                      • hendue
                        BenQ 2765HT vertical lines, no picture
                        by hendue
                        I was trying to fix the monitor, which was giving me the following pictures:
                        It was somehow reactive, such that if I pressed the buttons, the lines changed in positions or if i moved e.g. a task window, it would somehow change the patter, too.
                        I swapped out the mainboard without any luck. So I thought that it has to be an issue with the panel itself and was trying to assess whats wrong on the control board of the panel.
                        Somehow, I managed to short the LVDS protection with a MOSFETS cooler on the PCB.
                        I turned around...
                        09-09-2025, 08:27 AM
