Hi all. I have searched the forums and found similar posts, I have specific troubleshooting I have done thats why I posted a new thread. I have a 50" LG plasma I bought in 2009. Just popped and no picture. I try to turn it on again and tries to come on, makes a buzz noise by the z sus board, then quickly shuts off. If I unplug the z board from the power board (larger wires) and control board (smaller wires) the tv works but is dim and eventually turns mostly red color. If I connect the z sus to the power board, same thing. But if I connect it back to the control board it has the problem where it will buzz and turn off. No visual damage to any components that I can see. So I figure its either the z board or control board. I just ordered the z sus since that's what makes the buzz noise. The tv is a 50PS something. Any thoughts? I can post pictures and get the full model number if someone is listening. Thank you! Stupid tv!
LG pop of death - troubleshooting
Tags: None
Re: LG pop of death - troubleshooting
I would agree with your conclusion. It's pretty typical to see a dim picture without a functioning Z-board. Replacing that should be all that's necessary.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Thanks for the response. I just hope that when I change out the z sus that the control board has something messed up and causes that one to go too. Wouldn't figure that that particular connection would cause an issue...Comment
I have never seen a bad control board kill a sustain. It could happen, but it would most likely be due to bad software on the control board, not a physical fault.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Ok great, thank you. Amazing how many people have had problems. Although 1080p is awesome, they don't make tvs like they used to.Comment
Sorry, I forgot to ask: what would cause the screen to go red? I turned it on first thing this morning and it wasn't all red like last night when the tv was warm.Comment
When the Z-sus goes bad you get underdiffusion. This usually manifests itself as red or blue pixels misfiring, depending on the panel technology. Never seen it with green, but wouldn't rule it out.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by YanlebHi all, I just want to share the repair of my 60PK550-UA TV set.
The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
C57: 3.30V
C61:...07-20-2023, 12:38 AM -
by UL161I have a Whirlpool Side-by-side refrigerator that is only a few years old and I am now experience a problem where the cooling coil valve that enters the refrigerator side is not opening consistently. (the freezer is perfect ice cold). I have found out the problem can be overcome by simply pulling the power for a few minutes. Upon restart it works for some period then randomly stops. In speaking with a tech they claim this issue is likely due to an issue on the main control board. So I decided to pull it and I thought one cap looked bad so I replaced all 4... I thought I had solved it but ~24 hours...1 Photo
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by sam_sam_samI have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... - Loading...
