child lock on LG TV
  • morleebill
    • Oct 2012
    • 3
    • australia
    child lock on LG TV
    I have just repaired an LG PX3RVC-TA for a friend and the child lock is on, is it possible to unlock it without a remote control? some expert told me there was a battery which retained the memory, but I sure can't find one.
    Bill.
    Re: child lock on LG TV
    Hold MENU on TV and MENU on remote simultaneously to access the service menu. Then see if there's an option there or a factory reset.
    Sorry, no idea without remote. Maybe in main menu if you can access it.
    • gilly1984
      • 751
      Bill.
      If its repaired just give it back to your pal. Then he can remove the parental lock on it.
      Do NOT touch heatsinks when testing for voltages as they may be LIVE!
      • morleebill
        • Oct 2012
        • 3
        • australia
        You can't access the menu with the lock on, and I'm sure my pal would love to be able to get the lock off but he has no remote either.
        • drpj23
          • May 2012
          • 528
          I'm guessing the child lock just prevents the TV's buttons from working? or is it an actual password?
          Universal should work if the first.....menu--> special-->child lock-->off
          or try holding input for 10 sec (I have no idea about that one)
          And what does input and PR buttons do when set is off and on? (pressed together or simultaneously) (Def no idea on this either but hey worth a shot)
            LCD LED TV Service Menu Codes
            ALL LCD LED TV SERVICE MENU CODES
            Service Menu Code with Board Name
            China Universal Board / Jumper Board Service Menu Code
            Changhong Ruba Service Menu Code
            Ecostar LED TV Service Menu Code
            Orient LED TV Service Menu Code
            Haier LED TV Service Menu Code
            TCL LED TV Service Menu Code
            Samsung LED TV Service Menu Code
            LG LED TV Service Menu Code
            Videocon LED TV Service Menu Code
            Supra LED TV Service Menu Code
            Toshiba LED TV Service Menu Code
            Symphony LED TV Service Menu Code
            Veste/ LED TV Service Menu Code...
            10-31-2024, 03:58 AM
          • Monsterbeats19
            Techwood child lock eeprom dump
            by Monsterbeats19
            I have a techwood 50ao11uhda It has a child lock on the password has been forgotten that I can't figure out how to remove before I go buy a new main board I was wondering if anyone had a dump of the eeprom for this so I could flash it and save some moneys thankyou joshua
            12-08-2023, 11:45 AM
          • envym
            MacBook Pro 2018 with Activation Lock
            by envym
            Hi everyone!
            I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
            I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
            06-27-2025, 08:54 AM
          • cstout
            DeLonghi AC Remote only accepts 3V
            by cstout
            Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
            The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
            I can't find any schematics...
            06-03-2024, 03:53 PM
          • brock-s
            MSI A520M-A Pro with "U-Key" power-on lock removal
            by brock-s
            I've searched the forums, including review of the "BIOS Guides, Methods, Resources and Tools" section but could not find anything regarding this problem. Additionally, I could not find a thread related to a U-Key lock on an MSI motherboard (or any other brand board for that matter).
            I'm working on an MSI A520M-A Pro (aka MS-7C96 ver1.1) motherboard that displays "Warning!!! Please insert USB key press any key to check." upon power-on. This appears to be caused by a setting in the BIOS for "U-Key" being enabled. The owner states they didn't enter the...
            09-01-2025, 12:35 PM
