horizontal lines: ilo v23dlwx-u12
  • ryan74
    • Oct 2012
    • 471
    • usa
    i got this model ilo v23dlwx. when i first plugged it in and hit power, everything came on but screen was grey with vertical thin collored lines for a few sec. then a flickering blue screen that went to solid blue. so i tuned in the cable channel used for my cable box and picture had horizontal white lines. over time these lines faded but some were still there after 20min.
    i turned it on again and picture came up right away but had alot of horizontal lines again that mostly faded over a few min. there also seems to be a black bar across bottom about 1/2in. but its not there when i have a blue screen(no cable)
    i let the tv sit off/stby for a while and when i turned it on i got the grey screen, flickering blue-solid blue screen again. durring this phase theres no response from remote. after a min or so remote works fine. if i turn it off and on right away it work.
    i know my pics arent good but i have to use my phone so i included some part #.
    main board: v23dmbx-u12 03 543
    543L0812303000002295
    power supply: up1232a-01
    p/n: 6693006615
    panel: hsd230wx12
    b1L0na22a1a21a62140g0677n45ra
    te0000k64000001
    inv board: plcd09231202h
    5053910000
    0515
    board pictured im not sure of: hannstar 7072600a01 a1
    (no other labels on it) b4 05 20
    the back of the panel has a cage on it and the corner of it is slightly bent out of shape(left/inv side) and looks scuffed but theres no sign of it being dropped on plastic houseing. some pics are rotated/flipped sorry.
    any help with repairing this, or a service manual would be great.
    this appears to be the same: http://www.tgohome.com/ServiceManual...h=Submit+Query
    Re: horizontal lines: ilo v23dlwx-u12
    When the lines are visible, is the menu also affected by them?
    • ryan74
      • Oct 2012
      • 471
      • usa
      no the menu is not affected. only the picture. this time i turned it on and after it showed grey with vert lines it flickered blue, then solid blue, then black for 20 sec, then picture came on with white lines again.
      buttons were not responding so i unplugged/plugged it in again and picture came on right away and buttons work.
      if it is off a while it seems to malfunction alot until its warmed up a min or 2
      can you verify the manual i linked? the power module and main board numbers seem to match.
      • ryan74
        • Oct 2012
        • 471
        • usa
        when i first turn it on i get a grey screen with alot of thin vertical collored lines(up and down)
        after about a minute the picture shows up like in pic 105 above
        the longer the tv is on, the better picture gets, but its never perfect.
        • Ihandyrepair
          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
          by Ihandyrepair
          Hi guys
          I just started fixing 4k TV few months ago. so I am still learning a lot
          I got this tv from friend complaint is ghosting or horizontal lines on image.
          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
          then it started to show the ghosting white image.
          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
          it has 3 thin small boards at the bottom of the...
          12-05-2022, 04:18 PM
        • ggil44
          Sony XBR-65X750D Horizontal lines bottom of screen
          by ggil44
          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
          05-30-2023, 07:51 PM
        • noisykid
          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
          by noisykid
          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
          12-30-2024, 07:15 PM
        • x_orange90_x
          Samsung UN46C8000XFXZA Horizontal lines
          by x_orange90_x
          I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
          I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
          07-15-2023, 05:06 AM
        • Rubenlily
          Samsung QE50Q67TAU - horizontal lines
          by Rubenlily
          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
          I'm no expert but I've done the tape...
          08-16-2023, 01:12 PM
