LG Plasma 50PG100R Problem
  • VHSFI
    • Mar 2011
    • 47
    • Portugal
    Re: LG Plasma 50PG100R Problem
    So if i get OL in diode test mode with the Red Lead on the Small copper strip and the Black Lead on the Bigger copper strip, so i should apply the + of the power supply to the small strip and - to the big one ?
      That sounds right - you want the chips to normally be blocking the current rather than letting it through.
      Start with a lower voltage, 1-2V, and ramp it up slowly until the chip starts getting hot. It may be a good idea to remove those heatsinks too so you can easily see it.
      • VHSFI
        • Mar 2011
        • 47
        • Portugal
        Update:
        So did the experiment today it went rather well, started with a low voltage and slowly push it up to around 20v current went to about 350mA this for about 20sec was enought to see the culprit, top most IC on the top y-buffer started to get really hot all other IC's were cold, repeated with the other board and suprise surprise the exact same IC was bad too.
        I then removed that IC from one of the boards, witch was a bitch to do due to all the glue they have in there and due to the IC having a solder pad on the bottom (broke one of the tracks in the process), doing the diode test after checked ok so i pluged the board in the tv and now the screen lights to about 5/6 of the screen all white with some garbage around, voltages on the Y-sus (VY - VSC) all good.
        So this is starting to look like the panel went poof.
        Might try to transplant one of the good ic's and see how it goes, but there doens't seem to be much hope for this one.
          Hmm, I hope it hasn't, but you may find it has failed
          The TV just died, wasn't impacted or dropped or anything like that?
          It is potentially possible that maybe the topmost IC is weaker to other failures?
          • VHSFI
            • Mar 2011
            • 47
            • Portugal
            Yeah just died like that, one day finished watching tv turned it off, next day nothing.
            Btw can the Z side of things have anything to do with this, there is another voltage on that sticker on the back of the panel think is 94V, on the Z board there is a marking Vza or Vzs can't remember now near a resistor prety much like the VY & VSC on the Y board but i doens't read any voltage when measuring across it also there are 2 big heatsinks on the Z board but only one seems to warm up.
            Problems there too, or perhaps another indication of panel problems ?
              In general, no - the Z-sustain is only responsible for providing the second sustain drive. It alternates polarity with the Y-sustain to create the AC panel drive signal. If it goes bad you usually still get a picture, it's just very dim or purple tinted (due to insufficient discharge -- high UV content.)
              With no picture, there's no plasma drive, so you wouldn't necessarily expect the heatsinks to warm up.
              • VHSFI
                • Mar 2011
                • 47
                • Portugal
                #27
                The transplant operation didn't go so well, all that glue between the IC legs just make the solder procress very hard to do, i ordered some new ones should make the solder process a lot easier, meanwhile this is what i was able to get, well at least the screen gives coherent image the dead lines are surely due to soldering problems.
                  Note now whether the Z-sustain heatsink gets hot.
                  It could also be a loose panel connector with the lines.
                  It's looking like it might just be that the top IC likes to fry first (maybe because it is turned on first when driving the screen?) You should contact the seller about the failed buffer and get a refund.
                  I think your panel is good then, I would expect failures are quite rare (after all, it requires a join be made between adjacent lines, which is unlikely.)
                  • VHSFI
                    • Mar 2011
                    • 47
                    • Portugal
                    #29
                    Z-Sus is Ok
                    From what i read in a couple of parts sites it seems it's a common fault with some LG models including this one.
                    I'll make my final report as soon as i get the IC's. shouldn't take long to arrive.
                    • crashomatic
                      • Aug 2013
                      • 9
                      Gentleman,
                      I have a LG 50PG20-UA and I have no picture, sound is fine. Visual inspection shows no sign of trouble on the boards. If I remove the upper y-buff and I get the bottom half of the screen to go white, bright for a few seconds, then about half as bright. Upper y-buff back in and the screen gets nothing. Is this most likely a bad upper y-buff and is it worth ordering that card to see if it fixes it? Thanks.
                        It is probably best to create a new thread as your problem is quite different.
                        • crashomatic
                          • Aug 2013
                          • 9
                          Will do.
                          • crashomatic
                            • Aug 2013
                            • 9
                            Alas, I cannot post new threads yet. I will start one when I have been authorized.
                              You only need to post one post to start a thread I believe; that's typically the "new members" thread at the top of the forum.
                              • crashomatic
                                • Aug 2013
                                • 9
                                I thought I read that during sign up, but it is telling me I cannot start a new thread. (No permissions or not authorized.)
                                • kca
                                  • Feb 2016
                                  • 529
                                  Hello VHSFI (or anyone else connected to this thread) ~
                                  VHSFI ~~ Did you ever find a solution to your problem with this set?
                                  I have a very similar issue with an LG 60PX950.
                                  • rangaswami
                                    • May 2017
                                    • india
                                    #37
                                    all led tv dump how to dowenload
                                    • Capacitorial
                                      Powersupply has all the voltages - Monitor still no power
                                      by Capacitorial
                                      Hello guys,
                                      I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                      I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                      On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                      The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                      The weird thing is, that the Power LED is powered over the TCON board.
                                      On The TCON...
                                      12-28-2024, 02:12 PM
                                    • Spork Schivago
                                      Questions about Plasma voltages (PN60E530A3FXZA)
                                      by Spork Schivago
                                      Hi!
                                      I am working on a Samsung PN60E530A3FXZA and had some questions. The power supply looked pretty bad. There where heavy burn marks on the two thermistors and all the traces on the cold side from the larger transformer. For the larger transformer, there was discoluration on some of the traces for the hot side as well.
                                      I have seen other SMPS's for this panel that looked similar and replacing the thermistors did not fix the issue. The thermistors readed short circuit.
                                      Anyway, replacing the SMPS wasn't too expensive and I did along with the Y-Sustain board,...
                                      03-08-2019, 07:41 PM
                                    • gjgib
                                      Help reading schematic voltages input/output
                                      by gjgib
                                      Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                      I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                      I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                      I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                      05-06-2024, 08:11 PM
                                    • RossMoodley1967
                                      HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                      by RossMoodley1967
                                      Hello
                                      Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                      Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                      03-01-2024, 06:07 AM
                                    • lol999
                                      Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
                                      by lol999
                                      Motherboard after starting show Q code 00.
                                      No shorts on any rail ( at last I can't finde any)
                                      All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
                                      Nothing get hot, PSU starting, all lights came ON....
                                      One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
                                      After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
                                      This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
                                      01-21-2024, 02:25 PM
