where can i buy lamp for kf-ws60a1 chipest but high quality
sony kf-ws60a1
Tags: None
Re: sony kf-ws60a1
if your referring to ccfl lamps you can get good quality lamps at http://www.ccflwarehouse.com/ based in U.S.
by CyberPhoenixHello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
by Carlos#2003%Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
by Robin21Hello,
Does anyone have a motherboard from the Lenovo T490 model FT490/FT492/FT590/FT531 NM-B901 and could take a picture of the CPU area, including all the components around it? I would be very grateful.
During the CPU replacement process, I messed up all the resistors and capacitors, and now I can't get it to work again. The motherboard was powering up before, but now it doesn't, even with the newly installed CPU. All voltages are okay, and I don't have any shorts, so I'm assuming I'm missing one of the resistors.
I've also followed the schematic and Broadview,... -
by BiruslapioI got this 55 inch AU7X00 TV, it was rebooting and showed no image only a blink of the backlights.
I assumed it was either panel or motherboard. Turns out it was the panel, and after applying some tape on the ribbon cable that goes to the left side of the screen, the TV turned on with image, then I suddenly noticed a dark spot and the pixels were turning black on the left edge, I was sad and thought I smashed the screen somewhere, found nothing visually, it looked in perfect condition and if it was there before it would've been noticeable while I was inspecting the TV the first time.... -
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... - Loading...
