I have a ns-lcd42 insignia with no pic or sound power red light comes on when pluged in and when turn on the power light turns blue and back light comes on for a second and goes off
No pic or sound Insignia 42''
Re: No pic or sound Insignia 42''
How certain are you the TV has no sound?
Can you connect a video source with sound, then press the input button to switch through the inputs, and see if you then hear sound?
Also, is the full model just NS-LCD42?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
i have the same problem, I have a ns-lcd47hd, no sound no image even with a bright light. Led power indicater turns blue (stays solid and doesnt turn off or on until i push the power button), all voltages test right, have tried a new power supply and mainboard but neither fixed the problem, there is a voltage regulator and a capacitor on the new mainboard and both are getting hot.
my question is, should I replace the master and slave inverter boards
or should i replace the tcon boardsComment
@ocp, can we see the pictures of the Inverter boards/ I want to be able to see the 24V pin and the BL_ON/OFF PIN, you will need th check the DC voltages on those 2 pins.Never stop learning
im sure they are getting the correct voltage, he just replaced the power supply, theres going to be a failure of the master/slave power inverter or the tcon board.
Once I find the problem, I post a guide, I have found hundreds of the exact same problem with no one posting the fix.Comment
You need to look for BL_ON signal pin on the Master inverter board, I cannot tell you which pin that is until I see the pictures.Never stop learning
by MOSSEPHi
Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
I have already tried replacing all of the...-
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by kcaHello all ~
I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
No picture. No sound.
I tested all the voltages coming out of the power supply... -
by edugimenohI there!
Im trying to help a friend repairing a large, real-sized short-circuit robot.
This is remotely controlled and has a 2 way voice send/receive. Also while the hidden operator is talking, the red bulb inside the "mouth" should flash according to the sound
Some other technician used to service it and he was fired leaving all the repairs unfinished and no documentation at all.
What I found is a sound receiver, a speaker, and a wire directly to the mought bulb (a normal motorbike 5W 12V bulb).
So I bought a simple 2X30W amplifier to feed the loudspeaker... -
by slimsoulHi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power... - Loading...
