Re: 42" LG no backlights
That is it. Test it per post 26.
Your transformer pinout may be like this for the high voltage windings:
http://s807.photobucket.com/albums/y...t=DSC01034.jpg
You can see it in your picture in post 18, it is a 5-pins MOSFETs. it has that burnt jumper copnnected to one of its leg.Leave a comment:
i will can you tell me what U8 is please lol. Remember im new at this!!!Leave a comment:
Well, at least check out U8 as I posted in post 26 to find out taht is the reason the jumper burtn up. Then you will still have the transformers to deal with.Leave a comment:
hahaha replacing the board or buying a new TV???Leave a comment:
ok well for the price i will give it a try, wife bought me a new 55 LED so this is really just a learning lesson(and to prove that i can fix it lol). Thanks again will post when i get the new board.Leave a comment:
Well, we already know you have burnt out component on the board, so we know at least that the board is bad, cannot tell if there are any other problem with other boards on the TV.Leave a comment:
found replacement board on ebay for 45 dollars. Do you think that will solve my problem??Leave a comment:
That burnt jumper supplies the power to U8. That part has 5 pins, so take the resistance reading between all the pins, with the big tab on top, make the left pin as pin 1, then take the reading between pin
1&2
1&3
1&4
1&5
2&3
2&4
2&5
3&4
3&5
4&5
The transformer you have circle, you will have to do the same resistance checking between all the pins and compare the readings to the one next to it. I did not find the pinout of the transformer yet.
Also look on line for the replacement board.Leave a comment:
I better leave it to someone more in the know.Leave a comment:
the one spot is not where a jumper is. i circled where it is on the pic. That part also makes a strange noise when i plug in the television. It is the first one on the top of the board. not the one picturedAttached Filesif you find these attachements useful please consider making a small donation to the site
It may just be that they run quite warm, check for shorts and then patch up where that 0 ohm jumper went. Those other burn marks are where the other larger jumpers are.
It doesnt have to be super hot to make them marks.Leave a comment:
what about the other spots i highlighted they look burnt too?? Should i just order a new board?Leave a comment:
Just solder a wire across where the component fell off. But make sure there is no bronze showing on the trace inbetween the 2 points to be connected.
EDIT;
As bud said, better check for shorts before patching it up with a wire.Leave a comment:
The jumper that burnt up can be due to shorted load (MOSFET, Transformers, etc) or it has cold solder joints (lots of current flows through these jumpers).Leave a comment:
Fuses are usually identified with an "F". The component that fell off is identified with "JP", which usually indicates a jumper. The "0" stamped on the component indicates zero ohms, which is the same as having a jumper wire across the two points. What's the resistance reading of the component that fell off?Leave a comment:
by cajoegHello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV... -
by questoreHi Everyone,
I have 5 of these BX-BT1900 and 2 of them are not stating after a proper shutdown.
Symptoms:
- Computer starts as soon as power adapter plugged in and blue light turn on on the power button. Fan spinning, but no picture
- All power rails present and fine and CPU is slightly getting warm
- Nothing else is getting hot (thermal camera shows no exceptional heat)
- Tryed BIOS clean and reflash from here, but no luck. BUT someone suggested that I should try LPC clock temp fix.
I have found the LPC connector according to this documentation:... -
This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 05:50 AM
This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
- Loading...
