42" LG no backlights
    replied
    Re: 42" LG no backlights
    Can I see the front side closed up of that section to see what that connections are for?
  • cbriggz
    replied
    Ok guys sorry it took me so long to repost had a very busy weekend. Had
    24v coming off the board to the master and slave inverters. I then tested all the fuses and inspected the boards a little closer. Looks like i found the problem.... check this pic out tell me what you think. One of the little black fuses that was labeled Zero just fell off when i moved the board right were it looks burnt.
  • cbriggz
    replied
    i will take some close ups of that area tonight. i was looking for a small black fuse but didnt see one. will post later thanks!!!!
    replied
    Can you check the voltages and fuses as shown, and also good clear pictures of the area I redlined?
  • cbriggz
    replied
    ok thanks
  • gilly1984
    replied
    Originally posted by cbriggz
    not sure will check when i get home and repost thanks again. If so how do i go about testing the voltage on these?
    Multimeter.
    Black probe on chassis then check each pin with red probe. The connectors going to the inverters should be half gnd and half 24v, Should tell you on the board.
  • cbriggz
    replied
  • gilly1984
    replied
    Is the voltages marked on the board near these wires? (Circled)
    If so, switch tv on and test all voltages.
  • cbriggz
    replied
    i am new to this so not too sure where to begin checking the voltages. There is power at the main board and i see there is power to the board where you plug the components into(there is a little green light that is on). I have looked at the master and slave inverters and cannot see anything burnt or shorted out.
  • gilly1984
    replied
    Have you checked all the voltages? Be careful not to touch any heatsinks with your hands when it is plugged in.
  • cbriggz
    replied
    can anyone help?
  • cbriggz
    replied
    here are some pics
  • cbriggz
    replied
    ok will do when i get home from work. thanks
    replied
    The whole back of the TV so we can see how all the boards are connected together, then pictures of each board.
  • cbriggz
    replied
    what should i take pictures of? all the boards? the back of the unit is off already.
    replied
    Post good clear pictures using GO ADVANCED/FILE ATTACHEMENT function.
  • cbriggz
    started a topic 42" LG no backlights
    hey guys i am new at this but was looking for some help. I have a 42" LG lcd (model #42LG50-UA) that when i turn it on the power light flashes twice then turns blue just like it did when it was working correctly. I havent ever had any other problems with this unit and this was def. out of the blue. I took apart the back of unit and dont see any visual damage. the screen turns on for about 3 seconds and then shuts off. there is sound so was wondering if anyone can help walk me through this?
    chris
  • cajoeg
    Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
    by cajoeg
    Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
    The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
    02-10-2025, 04:01 PM
  • questore
    gigabyte BX-BT1900 BRIX Rev 1.2 blue led turns on but no start.
    by questore
    Hi Everyone,
    I have 5 of these BX-BT1900 and 2 of them are not stating after a proper shutdown.
    Symptoms:
    - Computer starts as soon as power adapter plugged in and blue light turn on on the power button. Fan spinning, but no picture
    - All power rails present and fine and CPU is slightly getting warm
    - Nothing else is getting hot (thermal camera shows no exceptional heat)
    - Tryed BIOS clean and reflash from here, but no luck. BUT someone suggested that I should try LPC clock temp fix.
    I have found the LPC connector according to this documentation:...
    01-05-2025, 08:13 AM
    Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
    This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
    09-07-2024, 05:50 AM
    Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
    09-07-2024, 05:00 AM
    Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
    This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
