Sharp LCD TVs in general
  • Technoguy3
    • Oct 2012
    • 30
    A friend of mine has a Sharp LCD HDTV that will randomly go black every so often. Oddly enough, hitting it will often make it begin working again.
    I thought about purchasing a Sharp HDTV earlier, but my friend's experience is causing me to second guess.
    Are Sharp TVs typically of bad quality or is this a mostly isolated incident? The forum members here have a ton of experience with this stuff!
  • crtfool
    • Jun 2010
    • 82
    Re: Sharp LCD TVs in general
    Open it up and see if there any loose connectors that are not pushed in all the way - I picked up an older Sharp for $5 that was doing the same thing, works perfectly.
      Sharp seem to be of decent quality. You get a few failures like any brand. However, watch out for newer smaller Sharp TVs (<=40"); they are just re-badged crappy Vestel TVs, not one bit of "Sharp" about them. Similar for Toshiba.
      Samsung and LG are the main ones I avoid unless I fix them first.
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • advant
        by advant
        02-03-2020, 12:25 AM
      • sefoster
        Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
        by sefoster
        I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
        11-20-2022, 09:29 AM
      • SONY_E-WASTER
        Help! Sharp LC-70UE30U 3 long flashes + 3 short flashes.
        by SONY_E-WASTER
        Hello, I'm new to this forum. I like to tinker with Sony electronics, I have been lucky trouble shooting sony stuff, But I can't find much info on this Sharp TV.
        The problem; plug to power>white led power indicator light is on>it turns on to the red Sharp logo>
        then the android logo is displayed, lit fine then the android logo brightness varies, then lit normal, then the tv restarts and does the same startup logos over and over for 5 times then it turns off and the power indicator light flashes the trouble code 3 long blinks plus 3 short blinks .
        does...
        12-26-2021, 05:46 PM
      • gavenb
        Sharp LC-80LE661U 80 inch
        by gavenb
        Hi folks!
        I have a LC-80LE661U that had some interesting issues.
        Initially, it would come on and show the sharp logo and would show normal static before shutting off.
        I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
        11-12-2023, 02:05 PM
