Panasonic th-42px500u random lockup
  • freakaftr8
    • Oct 2012
    • 3743
    Here's an interesting one that has me puzzled.
    I picked up this unit a month ago. Symptoms he told me are tv worked fine than all the sudden controls would lock up. Only thing that works is power. On the remote and on the panel. All other controls are frozen. Nothing works.
    Now if I'm on hdmi or any other port it's still working at the volume it was at. But controls locked up. Now if I let it sit a few days the osd and controls work for up to 10 minutes. Then go out. If I power down and back on the input osd is there but now frozen on the screen. The longer on and throught power cycles then eventually there is no osd. It just goes to the last used port at the last level of volume. Picture is still perfect but just no controls.
    Now the kicker is after about three power cycles after being plugged in while this symptom is occurring when I power it off there is a 20 blink error code. Now I've done my homework in this issue. Internet says it was an issue on some and a firmware update will fix it. Well it didn't. And a replacement dg board also didn't fix it. Now I'm thinking dt board. When the dt board is pulled the osd never works neither do the controls.
    This set sat for two months or more. And the first time I powered it up I didn't think it actually had a problem as the osd worked for like a day. It seems to be usage sensitive that makes me think cold solder joint on the dt or capacitor issue.
    Your thoughts? Thanks guys
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Panasonic th-42px500u random lockup
    On this issue I'm having. More research points to the dt board on this. What's the formula for testing silver lytic smd caps when they are still soldered to the board? I get really high and low readings when they are still installed.
      The fact that power works tells you something important. That's usually a separate signal and not treated like a normal button.
      I've seen plenty of TVs that don't register any button input when two or more buttons are depressed.
      Is it possible that a button is intermittently getting stuck?
      • freakaftr8
        • Oct 2012
        • 3743
        No I ruled that out. There was a moderately big issue with the px5 series 8th gen sets with this issue. It was either corrected with a firmware update which I tried and didn't work or just replacing the dt board. That always cured the issue. Something in the lines of whatever circuit on the dt board is in charge of handling the menus and controls goes wonky. But it's not heat related. I've tried heat and freeze. Neither correct it.
        • freakaftr8
          • Oct 2012
          • 3743
          However right now on eBay there's a board for the th-42px50u. Mines a th-42px500u. Cosmetically the sets are dofferent and on the dt board they have it is the same part number but there are some components that are not on the board that mine have. I've already tried replacing the dg board and the p board since i had an wxtra one. This didnt help.
            I doubt the DT would be compatible if it has different components...
            • freakaftr8
              • Oct 2012
              • 3743
              True. If a silicon ic went south then my understanding is that the is the the function of rhat ic will not work at all. Ever. Right? Something feeding this circuit has to be dropping off in voltage. Anyone have any info on a tnpa3524 dt board and its component functions? There is a lot of components on this little board and just trying to get the exact location of the ic that handles user interface.
                Nope, silicon can fail intermittently, too.
                Very common with voltage regulators.
                On a newer Panasonic, everything will be handled by that large SoC (system on a chip) in the middle of the board.
                On an older one, there will sometimes be a "sub micom" or "main micom" for handling the remote control functions.
                • freakaftr8
                  • Oct 2012
                  • 3743
                  That's really good info to know. Thanks!
                  • Dannyx
                    Panasonic PBX shuts off at random
                    by Dannyx
                    Good day folks. I wasn't too sure whether I should start this discussion just yet, because I feel I haven't dug deep enough, which I can't do until Monday at work, but I eventually thought I'd just go for it so by the time people start joining in, I'll hopefully be able to complete my measurements.
                    TL;DR - Panasonic KX-NS500 PBX sometimes dies - PSU issue (schematic attached). 41v rail drops to 25v and 15v rail goes off entirely. Often, even a power cycle doesn't restore it - main cap (C4) needs to be "manually" discharged for it go gain.
                    Details: to keep...
                    03-12-2022, 05:03 PM
                  • Andre Gilbert
                    by Andre Gilbert
                    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                    11-20-2024, 08:52 PM
                  • AquaMan Ua
                    Problem with PANASONIC CF53 laptop after changing BIOS settings
                    by AquaMan Ua
                    Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                    05-17-2025, 09:40 AM
                  • aa10aa10
                    Panasonic Toughbook CF-33 mk1 BIOS repair
                    by aa10aa10
                    Good day,
                    I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                    I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                    01-21-2025, 06:13 AM
                  • Mnawar27
                    Panasonic CF-H2AU24EF3 bios locked
                    by Mnawar27
                    Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                    I need help to remove it,
                    thankyou all.
                    SN; 2FKCA26876...
                    11-16-2024, 08:00 AM
