matsui mat32lw507 not turning on
  • wayne riley
    • Oct 2012
    • 6
    • ireland
    as i says above the tv stays in stand by mode and wont turn on. tried all the usual stuff like plug it out fa few a days and plug it back in. had a look at the capasitors and they all seem fine. does any1 know what the problem might be.
    the board type is 17pw20.1 010507
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: matsui mat32lw507 not turning on
    welcome to badcaps! please post clear pics of boards an just because they look ok does not mean they are! what tools do you have, a multi meter>? esr tester? soldering iron>?
    • wayne riley
      • Oct 2012
      • 6
      • ireland
      in the first pic bottom right you can see a orange colour fuse (c862) thing (new to this so dont have a clue)
      this fuse is not giving any reading. were as the same fuse (c836) on top left i giving a readig of 1427. could this be my problem an what is it called.
      ive also got a fuse (r960) under the box thing on top left not giving any readings. ive added a pick of said fuse. also no reading off c874 10uf but getting reading off c848 10uf of 972.
      sorry if im all over the place as this is my first time at this
        Ah, Vestel. We meet again :/.
        You can either replace the PSU (about £18) or you can fix it by replacing those two grey boxes (15nF 630V capacitors) near the top of the main transformer, as I've indicated in the image.
        Sometimes there are other causes of the fault, so I like to just replace the entire PSU when I work on a Vestel which is getting stuck in standby.
        • wayne riley
          • Oct 2012
          • 6
          • ireland
          hi tom. them two that you said are giving readings of 622 and 623.
          so will i still replace them? what about the other things i mentioned esp the orange fuse.
          can you direct me in the right direction to pick upa new board as im having trouble locating 1. im still going to mess around with the old 1 for experience.
          cheers tom.
            What are you measuring them on?
            • wayne riley
              • Oct 2012
              • 6
              • ireland
              on a digital multi.
              i have removed r96 c862 ad 874 as im not getting any readings rom tem in or out of board.
                What range of the meter?
                Ohms?
                Recommend you replace those components. 90% of Vestels have those caps failed. But personally, I've always found they have one or two more problems, and spent hours chasing the problem around, with no luck. Then again, I usually get the TVs in much worse condition, usually completely dead, so maybe those caps kill other stuff. Personally, I'm not sure.
                You can use 17PW15-9 as a substitute IF your connections match - check photo very carefully (I have done it before on a 32 inch Goodmans and Wharferdale, both Vestel chassis):
                http://www.ebay.co.uk/sch/i.html?_nk...at=0&_from=R40
                • wayne riley
                  • Oct 2012
                  • 6
                  • ireland
                  pic of meter below and settings its on.
                  sorry as im a total newbie here
                  • wayne riley
                    • Oct 2012
                    • 6
                    • ireland
                    just checked the 17pw15-9 looks very similar except for were the connections go there is 1 more block thats not on the 17pw20.1. would this be a prob?
                      I don't think it would be as long as it has all the right ones for the 17PW20 it should be fine.
                      Your meter is on 2kohm range, those caps do not seem right, but put back the resistor.
                      • postram
                        • Oct 2013
                        hello to you all , I hope someone can help me ,I have a matsui tv (MAT32LW507) and I iam having trouble has it will go to standby when switch on , then when I press the standby button on the tv to go power up ,the light gos dimmer (has if its on, BUT no picture (still a black screen ) ,I have looked at the trouble others are having with the same sort of problem ,but it all seems to be mixing me up what repair order I should go for (ie replace the two 15nf 630v capacitors 1st ) or what . please help ... mark
                        • drykid
                          Matsui 175S microwave fuse replacement
                          by drykid
                          I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                          Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                          12-21-2020, 01:15 PM
                        • corrize
                          A funny fuse story – Lumix LX100 II
                          by corrize
                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                          10-19-2023, 09:58 AM
                        • jesterace
                          Samsung UE46ES8000 Blown fuse but no other signs of short
                          by jesterace
                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                          09-11-2024, 03:14 PM
                        • jshhh
                          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                          by jshhh
                          Hi guys,
                          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                          Anybody know how to remove this type of fuse?
                          (The fuse is toward the bottom of the image labeled F2)...
                          06-17-2025, 01:35 AM
                        • Babbar
                          by Babbar
                          04-12-2024, 01:12 AM
