Samsung LED B6000 power failure problem
  • jeep26
    • Oct 2012
    • philippines
    Anyone has a power supply schematics for this model? The TV has no video and audio, when I looked at the PSU, ICE3BR0665J IC is blown. I can replace this but I would like to check on the schematics to see if any other components need to be replaced.
    Thanks.
    Regards,
    Jeep
  • jeep26
    • Oct 2012
    • philippines
    Re: Samsung LED B6000 power failure problem
    anyone can help me pls?
      What's the model of the PSU. e.g. BN44-xxxxxx
      • Espartaco Smith
        TV Samsung UE40MU6405U, not standby (after power failure)
        by Espartaco Smith
        Hello, as I mentioned in the title, I have a Samsung TV at home, model UE40MU6405U, which is about 5 or 6 years old.
        After a power company failure, the TV stopped turning on and even the standby light wouldn't come on. Over a period of about 10 seconds, the electricity kept going off and on repeatedly, and the TV died.
        The power supply is: L40E6_KSM (BN44-00875A)
        The main board: BN41-02568B
        The power supply board seems to be fine. All the voltages are present. If I disconnect it from the main board, I get backlight.
        I've also checked the...
        12-17-2024, 02:16 AM
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • Duranitron
        Asus x512dk rev 2.1 power on problem
        by Duranitron
        When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
        Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
        11-26-2024, 10:22 PM
      • EazyBone
        LG OLED55C9PUA power problem
        by EazyBone
        Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
        Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
        I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
        The power supply to t con is different story.
        This...
        06-23-2023, 07:43 AM
      • bcstedt
        Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
        by bcstedt
        Just starting to crack into this one and wanted to get the ball rolling.
        At power on (plug in), power light on, relays click, repeat (sometimes)
        After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
        Removed Y-Main for inspection and testing
        This pic from:
        PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
        12-15-2023, 10:30 AM
